Official torque specs thread
Old Apr 17, 2011, 01:01 PM
  #91
EvilEVO800hp's Avatar
just what im looking for
Old May 8, 2011, 06:43 AM
  #92
fromxtor's Avatar
I cant find my FSM disc and need the page with the diff mount tq values, if someone would post it up I would appreciate it.
Old May 12, 2011, 12:43 PM
  #93
machineman43's Avatar
what is the rod bearing clearance for a 2003 evo 8 2.0l
Old Jul 17, 2011, 02:07 AM
  #94
K20FD2R's Avatar
any pdf files
Old Sep 4, 2011, 10:49 AM
  #95
boostedwrx's Avatar
Evodan you can add this shot to the first page if you like. I upped it last night for another thread but thought it could go here forever
Old Sep 17, 2011, 03:35 PM
  #96
Z_Lancer_Man's Avatar
Bump!
Old Oct 13, 2011, 11:39 AM
  #97
evolutong's Avatar
Subscribed
Old Jan 5, 2012, 10:11 AM
  #98
kristian4802's Avatar
Great job guys thanks
Old Jan 5, 2012, 10:15 AM
  #99
EvoDan2004's Avatar
done thanks
Old Jan 24, 2012, 02:57 PM
  #100
fortyPSIrs's Avatar
What are the torque specs for all of the oil pump/front cover bolts, since they are different lengths, does anyone know what torque spec each one should have? (and maybe length?)
Old Feb 3, 2012, 09:11 AM
  #101
udluz's Avatar
nice
Old Aug 12, 2012, 05:32 AM
  #102
ben-_'s Avatar
thanks i needed the valve cover thank for that 31 inch pounds. thanks.
Old Sep 13, 2012, 12:45 AM
  #103
elim0's Avatar
am i missing it or does anyone know specs for swaybar links ??
also the specs for everything associated with putting the front motor mount in ?
3x14mm bolts for cross member support
3x17mm blots for cross member
2x14mm bolts for mount
1x through-bolt for mount
thanks !
Old Sep 13, 2012, 01:10 AM
  #104
Piro Fyre's Avatar
Originally Posted by evodan2004
REAR DIFFERENTIAL
Pinion Gear- 45ft lbs
Bearing Caps- 150ft lbs
I don't know about the pinion gear but the bearing caps should only be at 27ft-lbs.
Ring gear to the LSD is 26ft-lbs.
Rear diff cover is 26ft-lbs.
Old Nov 20, 2012, 07:58 PM
  #105
nexusone's Avatar
Can anyone please help me with the Intake manifold please. I have been going crazy trying to figure out the torque specs for the intake manifold. I found the specs somewhere but I don't know which bolt is which. I can't find a picture anywhere that shows each bolt and torque specs. Please help....
Quick Reply: Official torque specs thread
