Cosworth camshafts
Cosworth camshafts
Has anyone installed the cosworth camshafts. I looking to build my evo just saving up some money and i want the best avaible parts for my ride. Looking for some advice.
Anything higher then a 10.8 lift on a stock turbo your going to start to lose power on topend. I have the hks 280 and they are about the same as the 272 and they work great i put some cosworth's on a budys car and we have almost the same setup Aem and all i let him download my map in his car and he i put down 410whp on stock turbo while he only put down 375 becasue of the higher lift we redid the map a lil and only got 6whp more that is after 10 tune's later. Idles better then my car afr and damn near flat when at wot. The cams are just to high of a lift. Now when he put the 30R on the car the cams worked like a champ now he has 475whp at 25 psi with 100oct. and 462whp on pump with the same psi
Cosworth recommends getting these cams degreed, FYI.
I am loking into these, but am in the information gathering stage. If they are installed wrong, you will see less power than HKS.
I'm pretty sure the M2's are higher lift. Not sure about the duration. But here's the real info:
M1
http://www.cosworth.com/uploads/1147891236.pdf
M2
http://www.cosworth.com/uploads/1147891526.pdf
M1
M2
altvalet - thanks for the links. I'm really after the 'real world' experience with these cams. I'm really not as well versed in cams as to be able to tell their performance by them dimensions.... (yet)
