Broke something....What is it?
Old Oct 16, 2006 | 07:36 AM
zbomb's Avatar
I went to launch my car, broght it up to the 6krpm limiter did my normal clutch release and the car did'nt move, heard a awful noise coming from what sounded like the drivers side front. Now the car starts fine but when I put it in gear and start to release the clutch it is ok at first but as soon as the clutch should start to grab it does'nt and makes a awful noise. I am thinking I destroyed the clutch, any ideas.
P.S. No smoke, no oil, no visible signs of damage.
Old Oct 16, 2006 | 07:39 AM
Jasil's Avatar
Transfer case imo.
Old Oct 16, 2006 | 07:56 AM
DanJ's Avatar
What do you mean by aweful noise?
Old Oct 16, 2006 | 08:12 AM
zbomb's Avatar
Kind of a continuous grinding as soon as the clutch wants to fully engage. Not terribly loud. I am using a exedy twin disc. Anybody with TC braking experience?
Old Oct 16, 2006 | 08:22 AM
Ultimate CC's Avatar
You may have broke the TOB...
Old Oct 16, 2006 | 08:25 AM
Greg K's Avatar
if it was the throw out bearing the clutch wouldn't dis-engage. sounds like the transfer case or secondary shaft in the transmission to me. will the car move in any gear? Did you try anything other than first?
Old Oct 16, 2006 | 08:27 AM
zbomb's Avatar
yeah, it also moves in reverse, I will try to see if it will move in second. I just talked to my mechanic who thinks it may be the center diff or the tranny.
Old Oct 16, 2006 | 08:35 AM
Greg K's Avatar
does it make any "funny" or "bad" noises when backing up or releasing the clutch in reverse? How about turning in reverse? From the sound of it you "may" just have ripped out 1st gear...
Old Oct 16, 2006 | 08:36 AM
jqturbo's Avatar
The same thing happened to my boy, but he drives an 04' STi and it wound up to be his axle! I dunno! Keep us informed.
Old Oct 16, 2006 | 08:46 AM
zbomb's Avatar
Definately not just first gear, same sound happening in 2nd and reverse, also when turning the wheel. The car is now very reluctant to move in any gear. My car is f'ed.
Old Oct 16, 2006 | 09:03 AM
Evoryder's Avatar
TC is toast...twin discs and tc's don't like each other
Old Oct 16, 2006 | 10:59 AM
jrsimon27's Avatar
yep its the transfer case a friend of mine has a twin disc and he blew up his transfer!
Old Oct 16, 2006 | 01:22 PM
zbomb's Avatar
Would the car be able to move at all if it is the TC. At first it would start to roll until the clutch was suppose to fully engage. Now it won't budge.
Old Oct 16, 2006 | 01:48 PM
jrsimon27's Avatar
better tow it
Old Oct 16, 2006 | 01:51 PM
tarmac4g63's Avatar
your tc is probably toast
