stiffer rear end mounts
Old Oct 22, 2006 | 05:16 PM
superflyevo's Avatar
were can i get the stiffer rearend mounts
Old Oct 22, 2006 | 07:05 PM
kekek's Avatar
If you are talking about the rear diff mount bushings there are 2 options I know of.
Energy Suspension and Works, although works may not sell the mustache bar bushings. Install isn't too bad except you have to drop the rear subframe to get the bolts out of the mustache bar since the gas tank is in the way.
HTH
Old Oct 23, 2006 | 10:16 AM
Jamie@WORKS's Avatar
http://www.worksevo.com/store/produc...products_id=69
The WORKS USB Rear Diff to Chassis bushing is available now and the Rear Diff Support Arm bushing should be available soon.
Old Oct 23, 2006 | 12:36 PM
thanks
sooo the install anit that bad?
Old Oct 24, 2006 | 11:06 AM
kekek's Avatar
Originally Posted by superflyevo
thanks
All of these bushings are large enough that using a hacksaw to cut through the outer bushing sleeve and simply tapping them out works quite well. The worst part is dropping the rear subframe, although it's not exactly terrible. I did it with the car on jackstands too.
