knock count
C6, Don't feel to bad, my car is almost always apart or up on my lift.. I give you credit for doing the clutch yourself.. Its something I refuse to do on these cars and I'll work on nearly anything.
Cant wait to get it together drive, not to mention log with the new stuff out
Personally I would pay a vendor to custom map your car and then use that as a base to fine tune from logging. You will have a safe mode to go back to.
Originally Posted by purevibez
hey guys just installed my cams- 272's all around. was just wondering how much advance and retard i should be running on the intake and exhaust. im running +2 intake and -2 exhaust right now.according to my mitsulogger im getting a little knock in the middle from 3500-4500 from 4-5 counts then lots of 3's to 5600 tell me what u guys think.im running a flash, but its not set up for the cams just all the bolt on stuff.
thanks in advance
ps included the log from the run.
thanks in advance
agree
yeah thinking about it might have jestr do it or send me a flash. but im still playing around with the flashs i have can never learn too much. but that might be the best bet right now aswell.
im slowly getting the knock out as for the gas thing yeah its a good idea but with the minimal knock im getting less and less ill jus keep my foot off the throttle and shift it like a normal car im only at wot when im logging. speaking off ill be posting a new log soon as i get a good one from top to bottom.thanks everybody.
My head hurts trying to read that.
ok kapolani, since you want me to use proper grammer. I logged a few runs, not too bad. since I adjusted the cams to -1 intake and +1 exhaust the knock is almost gone completely. suggestions to get the rest of it out? Thanks for the help with the immobilizer problem jack. Turned out the key and immobilizer had to be resychned and the code from the ecu that mitsu gave me was right after all. The car is up and running now.
ok running -2i,-2e and the car feels great the knock i think is gone but wont know till i get some logs in. also c6 im having john from jestrtuning build me a tune. so thanks all for the advice. oh congrats on finishing your clutch. i did mine on my own and it was a pain in the ***. plus i had a lift.
here are then new logs. pulled them last night at like 4am on the way home from work. it was cool and a little humid. thoughts? oh and john @ jestrtuning is building me a tune, so we will see how it is after that aswell. thanks guys
as always
as always
as always
as always
ptm5070
21
Nov 5, 2015 05:19 AM
krillin
Feb 6, 2007 10:01 AM
