best cam gears for tuning?
Old Nov 20, 2006 | 04:59 PM
sonicnofadz's Avatar
Originally Posted by stance
Bumped for suggestions ... I have a HKS cam gear lying around. Would it be worth getting it fitted along with the GSC cams I have or should I just sell it and not take the risk of a cam gear slip?
Thats entirely up to you. Personally, I rather not take the chance. The chances of it slipping go up the more powerful your engine is (the more power the engine has the harder the timing belt gets "jerked" when going wide open throttle).
Old Nov 20, 2006 | 05:41 PM
boscoyo's Avatar
Not sure if there is a best in cam gears, but if there is, it would be a set that does not move after they are set. Tomei and Unorthodox makes some top quality cam gears.
Old Nov 20, 2006 | 11:04 PM
stance's Avatar
Thanks guys for the feedback, I've made up my mind not get them fitted. It will cost me more to have something go wrong, than to look for other mods to gain that extra power.
Old Nov 21, 2006 | 06:03 PM
Gruppe-S's Avatar
5 Bolt is good. And weigh your cam gears guys! There's DEFINITE advantages to running a lighter cam gear due to the diameter of the gears. I know the HKS weighs in at 1.23lbs the Helix UL at .99lbs. Not sure what the rest weigh in at, don't know if anyone wants to list the weights.
Cheers,
Gary
Gruppe-S
TwistedEvo8
26
Aug 7, 2016 06:48 PM
audiofan
Oct 6, 2011 06:33 AM
ryukinevo
Aug 11, 2011 10:10 AM
Carrier
Lancer Engine Tech
Jan 9, 2007 09:56 PM
titaniumkingpin
11
Nov 29, 2004 01:43 AM
