Boost goes to 29psi in the 2-step!!
Old Dec 20, 2006 | 11:05 AM
EVIL_EVO_VIII's Avatar
Question Boost goes to 29psi in the 2-step!!
So im standing at the light last time i went to the track while i was getting ready to stage... So i hit the 2step to see what boost goes to and it just kept going up and up till 29psi After i left off the gas, the car wants to stall and it smells like fuel all over.. Why is it doing this? Before it would go to 8-9 psi max
Old Dec 20, 2006 | 11:07 AM
DarksideEng's Avatar
Ask Scott, I bet he would know best about your cars tune.
Old Dec 20, 2006 | 11:11 AM
newimportowner's Avatar
Holy Crap
Old Dec 20, 2006 | 11:14 AM
Kee1pride's Avatar
maybe theres a hole in one of your boost controllers lines...
Old Dec 20, 2006 | 11:16 AM
Smike's Avatar
Or a line came off - you are max boosting.
Old Dec 20, 2006 | 11:23 AM
joeymia's Avatar
because your car started to knock and timming was being pulled. how long did you sit on the 2step?
Old Dec 20, 2006 | 11:39 AM
for like 10-15 seconds.. Also what do you mean knocking and pulling timing? The car was at a stop so im confused as what ur referring to
Kee1pride.. I checked all the lines and everything is fine.. Not sure if it has to do with the tune
Old Dec 20, 2006 | 11:41 AM
boostinjuice's Avatar
i dont think your supposed to sit on the 2 step for 15-20 seconds
Old Dec 20, 2006 | 11:42 AM
-=SPECTRE=-'s Avatar
You're not using the ECU for boost control so it's not directly caused by the tune.
How are you measuring boost?
Old Dec 20, 2006 | 11:54 AM
my boost gauge... It never used to do this before.. One of my friends with a IX was having the samething and i didnt believe him till it happened to my car
Old Dec 20, 2006 | 12:02 PM
Evo Girlie's Avatar
Max u are suppose 2 hold 2-step is 4 to 5 seconds, i held mine for a bit above once and it boosted up to 16psi.
Old Dec 20, 2006 | 12:05 PM
4WS Tuning's Avatar
same here... ^ after 8/9 seconds it does it almost every other time...
cheers!
Old Dec 20, 2006 | 12:08 PM
Why would you hold your LC for so long? You're only supposed to use it for a few seconds.
Old Dec 20, 2006 | 12:10 PM
Nez136's Avatar
^some of us guys with the larger turbos need a little bit longer to build boost at the line.
Sometimes it starts to build boost high immediately
