Just Installed Clutch and Flywheel:
Old Dec 20, 2006 | 03:56 PM
1BlackEvo9's Avatar
I just had the ACT Xtreme Clutch and Fidanza flywheel installed. My question is how do I know if they adjusted it correctly or not? The clutch is definitely alot more grabby and feels pretty good, but I want to make sure that it is adjusted up right. Is there something I can do to check this out?
Old Dec 20, 2006 | 04:36 PM
s10v8's Avatar
If you want to check to see if its all good, drop the trans and check it out.
Old Dec 20, 2006 | 04:39 PM
1BlackEvo9's Avatar
Yeah ok, that's not what I meant. I want to know how you can tell if the clutch pedal has been adjusted right.
Old Dec 20, 2006 | 04:41 PM
s10v8's Avatar
Lol. Sorry for being a idiot. Take it to Mitsu and have them take a look. If thats out of the option's. I dont know how to Help ya. Sorry for the misimformation.
Old Dec 20, 2006 | 05:29 PM
1BlackEvo9's Avatar
No problem.
Old Dec 20, 2006 | 06:54 PM
Danny23's Avatar
the clutch should start to grab half way up or a little more.Adjust the free play at the top to about 3- 5 mm of play and you should be fine.
Old Dec 20, 2006 | 07:01 PM
hondafan's Avatar
TRE reccomends putting all 4 wheels off the ground and adjust the pedal until the wheels start turning when the clutch pedal is 2-3 inches off the floor.
Old Dec 21, 2006 | 04:38 AM
1BlackEvo9's Avatar
ok, what about if the pedal sticks when fully out. What I mean is that just before it is fully out it will stick about an inch or two under the brake pedal.
Old Dec 21, 2006 | 05:42 PM
hondafan's Avatar
did you bleed the clutch line yet? try that.
Old Dec 22, 2006 | 06:08 AM
1BlackEvo9's Avatar
yeah everything is good now. The pedal was sticking low because of the bump stop and I adjusted the clutch up a little higher and everything seems to be ok.
ohYouEvo
Aug 28, 2016 10:58 AM
XK120
Dec 28, 2011 08:45 AM
toddcfii
19
May 7, 2011 02:24 PM
Normanruben
Dec 8, 2006 05:09 PM
prototypemike
Lancer Tranny/Drivetrain Tech
11
Mar 27, 2005 07:46 PM
