Zeitronix ZT2
Zeitronix ZT2
Not sure what section this should be in, so if it belongs somewhere else, mods please move.
I'm going to order the Zeitronix ZT2 Wide band, but I have a couple of questions.
I already have SW Boost, EGT, and Oil Temp in my car. So I'm wondering what would be the best option.
1) Use the ZT2 along with the SW gauges already located in the car. From what I've read the pieces to get the boost numbers and EGT are extra anyway. So would I just be getting the AFR from the ZT2 at this point??
2) Use the ZT2 and purchase the extra pieces so it can show the boost readout and EGT. Take out the boost and EGT gauge and put in the SW oil pressure gauge I have laying around to go along with the Oil Temp that's already in there. Then pick up another SW gauge to fil the 3rd slot in the Gruppe-s piece I have (not sure which one would be worth getting)
3) Same as number 1 except get the pieces to use the boost feature on the ZT2 and replace the SW boost gauge with the SW Oil Pressure Gauge I have here. How much more accurate is the ZT2 boost reading over the SW boost reading??
No matter what my choice above, I'll probably be getting the LCD display and ZAVT-1 along with it.
Where in kissimmee do you live man?
Haven't seen a blue evo around.
BTW....for the original poster....I would recommend using the Boost sensor with the ZT2, since this will allow you to log via the Zt2. Also the boost sensor on the Zt2 is a VERY precise piece.
Apex Hunter
Sep 15, 2015 10:21 AM
TTP Engineering
Evo 'For Sale' Interior Styling
141
Jun 3, 2010 10:21 AM
