Clutch and Restrictor Removal?
Old Dec 31, 2006 | 10:11 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
So after 2 years of abuse and launching my stock 05 GSR after about 30k the clutch is finally taking a poop on me. So after speaking with a few EVO-NY members I have decided with my power goals in mind. I’m going with an ACT street clutch kit and stick flywheel. But my real question is and keep in mind my whp goal is about 300-350 daily driven but it will on occasion be taken to the track and put to the test. So that being said should I remove the clutch restrictor? Is worth it in the long run?
Old Dec 31, 2006 | 10:13 AM
nObject's Avatar
I just got the Exedy Twin Disk and left the pill in...for daily driving to be comfortable I would leave it in..
Old Dec 31, 2006 | 10:18 AM
Apex Racer's Avatar
I took mine out a lon gtime ago, I have the ACT clutch with fidanza flywheel. I DD mine and aside from the period where I was breaking in the clutch I never had a problem.
Old Dec 31, 2006 | 10:20 AM
EvoDan2004's Avatar
same here. same clutch. i still got my pill in as well. i wonder what it would be like without it though at the track. could i better my 60's????????????
Old Dec 31, 2006 | 10:21 AM
vmrevo9's Avatar
Veteran: Air Force
what does taking the restrictor off do?
sorry for the noob question.
Old Dec 31, 2006 | 10:41 AM
DBallz's Avatar
Well thanks spoke to a old buddy of mine and I think I'm going to take it out. My buddy had the exedy twin plate in his 03 and he took the restrictor out he had no problems daily and he launched that car for about 30k probably more so than most of us
Old Dec 31, 2006 | 11:02 AM
ries's Avatar
the restrictor pill is inside the slave cylinder and restricts the amount of fluid flowing inside to slow down the engagement of the clutch if you side step/drop the clutch. Its another one of mitsu's ways of trying to keep stupid people from destroying tranny's and transfer cases
Old Dec 31, 2006 | 11:04 AM
ries's Avatar
since your down there you should change the clutch line out for a ss braided one...
you'll get more consistent clutch engagemeng/disengagement and they're pretty cheap too
Old Dec 31, 2006 | 11:06 AM
Apex Racer's Avatar
Like I said, i have had mine out for a long time I have not experienced any DD issues. I am sure that just as long as your not acting a fool you will be fine removing it.
Old Dec 31, 2006 | 12:46 PM
DBallz's Avatar
Oh yeah I already have it I'm actually just waiting for the clutch in the mail
Old Apr 26, 2007 | 08:56 AM
rudebwoyt's Avatar
The Clutch restrictor is one of, if not, THE reason, EVO clutches wear so quiclkly.
Its the "safety valve" in the drive train. And if you think about it, the clutch is probably the cheapest part of the drive chain to be replaced.
If you remove the restrictor, you will get more life out of the stock clutch, and therefore any aftermarket ones.
Old Apr 26, 2007 | 09:35 AM
BluEVOIX's Avatar
Is this true? Wow, maybe Mitsu put it in just to have peoples clutches wear quicker rather than save them and have them comming back in to replace a wear and tear item.
I'm going to search the howto section to see how its done.
Old Apr 26, 2007 | 10:43 AM
MasterNater's Avatar
http://evomoto.com/tech_info.php?tPa...ef3c4455f4f4a2
Old Apr 26, 2007 | 10:46 AM
sabastian458's Avatar
I did mine and love it. ACT HD, ss line
Old Apr 26, 2007 | 12:39 PM
AlwaysinBoost's Avatar
I felt ZERO difference with my exedy twin when I removed the restrictor.
