PCV Rotation ??
Old Jan 1, 2007 | 10:00 AM
cij911's Avatar
PCV Rotation ??
I am trying to install the DC3 can to the PCV and am having trouble - the PCV angle is causing the hose to kink slightly. How can I rotate the valve ~150 degrees so that it is pointing towards the driver side (left side) ?
I tried moving it but it feels like it is not meant to be moved ...Thanks
Old Jan 2, 2007 | 04:18 AM
cij911's Avatar
Any advice from the pros ???
Old Jan 3, 2007 | 07:46 AM
cij911's Avatar
morning bump.....
Old Jan 3, 2007 | 11:44 AM
Fourdoor's Avatar
I personally just used a long section of hose so I could get a gradual bend in it.... I think the PCV valve itself just screws in, but if you tighten it too much trying to face it the other way it could strip the threads.... and if you turn it the other way it may not be tight enough.
Keith
Old Jan 3, 2007 | 03:26 PM
cij911's Avatar
Keith
Thanks Keith!
Old Jan 23, 2009 | 10:50 AM
Ph3n1x's Avatar
any luck?
Ckeesee12
Jul 28, 2017 09:23 AM
TariqEvo
Jul 17, 2017 07:21 AM
Tougefreak
May 25, 2017 06:20 PM
jason42003
Dec 18, 2014 03:51 PM
BluEVOIX
Apr 3, 2007 11:52 PM
