results from tuning my IX!
baseline (stock)
229WHP
228WTQ @ 3900
PSI would hit 19 @ 3500 rpm and then taper off
after install of MBC, fuel pump and a reflash by Chris at AMS
264WHP
285WTQ @ 3500
PSI would hit just under 25 @ 3100 rpm and then fall off
wish i had a scanner to put up the sheets. both pulls were done on same dyno which is a dyno dynamics in Houston. Car feels amazing and can't wait to start doing more stuff.
229WHP
228WTQ @ 3900
264WHP
285WTQ @ 3500
Nice gains, but that's a LOT of boost on 93oct and stock exhaust. It would seem most of the gains came from the 6psi increase in boost, too. You were logging boost through the dyno, and it showed 25psi below 3100rpm? Were you in 4th gear?
