CEL Light : EGR Insufficent air
Old Jan 13, 2007 | 11:46 PM
EVO-8-YOU's Avatar
So i was driving today and the car started fuel cutting then a CEL light came on. lowered the boost and still fuel cut anyone have any idea what this is ? code came up as EGR air / fuel flow.
Old Jan 13, 2007 | 11:52 PM
boostingevo8's Avatar
Yea bro your line popped off your EGR valve in the back on the manifold right below the throttle body. Take you hand, stick it behind the throttle body and feel around and you should feel the loose line. Reattach the line to the EGR valve by feeling for the nipple on the EGR valve.
Old Jan 13, 2007 | 11:55 PM
EVO-8-YOU's Avatar
let me try that out.. anything else it might be ?
Old Jan 13, 2007 | 11:58 PM
EVO-8-YOU's Avatar
just checked it couldnt really find anything.. can you get more specific please.
Old Jan 14, 2007 | 12:01 AM
EVO-8-YOU's Avatar
Originally Posted by Topracing
IK had the same problem
Howd you fix it
Old Jan 14, 2007 | 12:41 AM
EVO-8-YOU's Avatar
bump
Old Jan 14, 2007 | 12:34 PM
EVO-8-YOU's Avatar
can anyone help ?????
Old Jan 14, 2007 | 12:36 PM
kreionic's Avatar
reach behind the throttle body. There will be a nipple back there feel for it. Reach down a little farther and there will be a vacum line there. Plug it in the nipple , zip tie it and your good to go. You can't see it so its all done by feel.
Old Jan 14, 2007 | 12:39 PM
purevibez's Avatar
use the force!!!! it happen to me too kid. same fix
Old Jan 14, 2007 | 12:40 PM
boostinjuice's Avatar
+1
Old Jan 14, 2007 | 12:51 PM
EVO-8-YOU's Avatar
thanks =]
Old Jan 14, 2007 | 01:05 PM
QwikEVO's Avatar
if you'd do a search on your CEL code, there's plenty of threads on this.
Check the line on your EGR valve. I had the same problem twice, and I ziptied the sh*t out of the vacuum line and I haven't had the problem since.
Old Jan 14, 2007 | 01:09 PM
Evoryder's Avatar
+1 ...it kept popping off for me...so i took off the damn upper strut bar and zip tied the ***** of that nipple...been about 5months since that code...used to drive me nuts...easy fix...feel back there and you feel the tube hanging and then find the nipple
Old Jan 14, 2007 | 01:48 PM
EVO-8-YOU's Avatar
i reached back there but is it on the left side of the throttle body or next to my charge pipe ?!? is it true that the egr valve shouldn`t matter isn`t it just for admission ? why would it **** up my boost?
Old Jan 14, 2007 | 01:51 PM
gsrboi80's Avatar
If you realy look for it youll find what the above posters are talking about. ((.(% sure that is your poblem. Its fairly common man
