questions on mbc and dv!
Old Jan 15, 2007 | 04:14 PM
evobeatsti's Avatar
hey guys i am currently ordering some new parts for my car and wanted your opinions on a few things.
1. what is the best mbc out there for a reasonable price. i know the ams and buschur ones are like $70 but do they work well or should i get something like the forge or hallman mbc. i want to try to keep the price down but do the more expensive forge and hallman ones offer anything that the ams or buschur ones do not offer?
2.there are numerous diverter valves out there and i plan on running around 27-28 psi on race gas which i believe the stock plastic or the jdm ix diverter valves cant handle. so i have been looking at the forge offerings and want to know which one is the best, the rs, the 15, or is there something else i should look at remember i need a recurculating one no vta.
well thats all and i hope i can get some answers.i did do a quick search and couldnt turn up any results so plz help me out here. thanks
Old Jan 15, 2007 | 04:22 PM
scottatyamaha's Avatar
1. The Hallman or forge unit
2. The forge RS
Old Jan 15, 2007 | 04:28 PM
CAD EVO's Avatar
Well I can't possibly say which is the best dv cause I've only had expirience with my evo 15 valve, and its the $hit.
Old Jan 15, 2007 | 04:31 PM
Warrtalon's Avatar
1. Forge Unos or Hallman Pro - they are only $85 - not really "more expensive." The Forge has built-in detents that click when you turn it, which is great for keeping track of exactly where you've set it for different applications (pump gas vs race gas).
2) Forge RS over the Evo15. It has an adjustable knob for stiffness to optimize your setup from 20 psi to 40 psi, and it doesn't have springs that must be changed.
3) I do not believe that you searched and found no info on these. I couldn't begin to count the many times that these same recommendations have been given to other noobs, and as you can see (if you look), these parts are what I chose for the Warrtalon packages I created, because they are the best.
Old Jan 15, 2007 | 04:57 PM
evobeatsti's Avatar
thanks guys, warrtalon i said that i did a quick search but thanks for the advice!
Old Jan 15, 2007 | 04:59 PM
evobeatsti's Avatar
what vender sells the forge mbc and dv for the best price does anyone know?
Old Jan 15, 2007 | 05:19 PM
Warrtalon's Avatar
Check with Buschur, or check with TTP.
