Garrett Turbo sizing????
Old Jan 19, 2007 | 03:52 PM
T67Evo's Avatar
Well apparently you do... lol. Anyways that kinda bums me out. The damn thing doesn't get to 20lbs till 4000 rpms. Marco from billet design seems to think it is close to a GT35r but wasn't too sure. The compressor side of this thing looks bigger than a GT35r.
Old Jan 19, 2007 | 07:55 PM
jj_008's Avatar
Originally Posted by Ted B
I thought the larger hotside would make it a TD07XX-25G or thereabouts. But then again, I don't profess to be an expert in Mitsubishi turbo nomenclature.
The funny part is the T67 and TD06-SH25G don't even use a true TD07 turbine. The TD07S-25G and the T78 both use a 7mm bigger inducer and exducer.
Using the term "25g" is about as useless as stating you have a GT30R .
Old Jan 19, 2007 | 07:58 PM
jj_008's Avatar
20lbs at 4000rpm with a fourth gear pull is really good with a T67.
The bigger compressor cover is to help with surge.
Old Jan 19, 2007 | 08:00 PM
purevibez's Avatar
intresting
Old Jan 19, 2007 | 08:07 PM
Gruppe-S's Avatar
The thing with the TD06-Reverse wheels it that they're big - much larger in diameter than the GT30 turbine wheels. The Garrett turbos employ a longer inducer/exducer length on the turbine wheel to maintain surface area but reduce rotational mass (by reducing the diameter). The TD06-R wheels weigh anywhere from 0.5-0.8oz more than the GT30R turbine wheels and as I recall are ~7mm larger in diameter - I'm sure you can see why there's more lag.
That said, the TD06 wheels are good for consistent 10's on the EVO with a properly setup car.
Cheers,
Gary
Gruppe-S
Old Jan 30, 2007 | 08:40 AM
Talonmotosports's Avatar
Does anyone have any information on where i could get my Greddy 25G turbo (the one that comes with the kit) upgraded, or atleast buy the larger cartrige for it?
thanks
Voltexed
Oct 20, 2016 06:30 PM
hutch959
14
Apr 6, 2016 12:42 AM
riceball777
21
Dec 12, 2015 07:18 AM
chuntington101
33
Oct 23, 2011 12:58 PM
joprout
Dec 19, 2009 08:01 PM
