overboosting after 6k rpm?
Old Jan 21, 2007 | 01:36 PM
BoOsTinGEVO190's Avatar
What's up guys I installed some tbolt clamps and apexi intake filter and hallmans mbc that I took from my old evo for some reason at 3500rpm it hits 20psi like it suposto but after 5500-6krpm it shoots up to 22-23psi and stays there? All the way to redline I let go right away that's in 3rd gear in 1st or 2nd it doesent do it anyone know what would be the problem?
Thanks
Old Jan 21, 2007 | 01:43 PM
Danny23's Avatar
some people wouldnt call holding 22-23 psi at redline a problem. But i get your concern. Try turning the boost down a bit in third gear pulls and see what happens.
Old Jan 21, 2007 | 02:24 PM
Probably need a tune just did another pull 3rd gear got a boost cut around 7k rpm lowered the boost for now you guys thinkn its a bad mbc? Or hoses I never had that problem with my 8 even without a tune? By the way I have defi bf boost gauge
Old Jan 21, 2007 | 02:47 PM
Warrtalon's Avatar
That is very abnormal. The boost should not climb after peaking at 3500rpm, and it should not keep going up at high rpms - it should be tapreing down. Do you have any other mods or just an intake and MBC? It almost sounds like your WG turnbuckle is not set properly, which is causing a weak initial spike then allowing it to continue climbing to the actual preset boost (which would be well over 22-23, but you wouldn't know). If this same MBC worked well on your VIII, then it shouldn't be the MBC. What hoses did you use on the IX, and are you sure you didn't install them backwards?
Getting a tune would not be relevant in this situation.
Old Jan 21, 2007 | 03:32 PM
I have a TBE apexi filter mbc that's it does it matter what hoses I used I mean size wise ? I the stock hose that already was on the bov to the T of the mbc?
Old Jan 21, 2007 | 03:37 PM
Warrtalon's Avatar
It does matter, but not so much the size as long as they're within reason.
I don't understand your last question. What were you saying? If you used any of the stock BOOST hoses, then that is your problem, but the stock hose going to the BOV nipple is fine for reuse.
Old Jan 21, 2007 | 03:39 PM
steevo's Avatar
Don't use the stock boost lines. They have restrictor pills in them that will cause problems with a mbc. Use new lines with no pills, and reset your mbc all the way down. Then, turn up.
Old Jan 21, 2007 | 03:48 PM
Old Jan 21, 2007 | 03:54 PM
Z-Ball's Avatar
sorry about this question, but warrtalon what kind of mbc do you use
Old Jan 21, 2007 | 04:05 PM
Warrtalon's Avatar
Posted the same thing 10 mins later? Hah, must have screwed up and hit submit again later or something.
Z-ball, check my Warrtalon package for that info!! I use everything in the VIII Warrtalon package.
Old Jan 21, 2007 | 04:06 PM
No I used all new hoses except the one that comes off the bov line the little hose and warrtalon I was talking about the samething you said the bov line I reused it for T would a bad mbc do that?
Old Jan 21, 2007 | 04:11 PM
Warrtalon's Avatar
Run-on sentences pwn!!
Re-using that small hose on the BOV nipple for your TEE is fine. The Hallman shouldn't be bad, but I guess it could be. Are you sure you hooked the hoses up to the right nipples on the MBC? It's easy to get them backwards.
If you got the hoses right, then try going back to stock and seeing what happens. If it's fine, then find another Evo owner with an MBC and try his.
Old Jan 21, 2007 | 04:13 PM
Schuyler's Avatar
You're being all nice Warr - get some good sleep last night or a nice wake-up call?
Old Jan 21, 2007 | 04:17 PM
Z-Ball's Avatar
hows the spike on the forge unos mbc
Old Jan 21, 2007 | 04:27 PM
Warrtalon's Avatar
Same as other MBCs. Depends more on the installation method.
