jun cams,valve springs and retainers
i think the car has jun cams valve springs and retainers..are there any disguishing marks , part numbers or anything where they say jun or anything that can tell me what they are on them...if so thatd be great...pics to would be awesome..thanks
ps-by the way i tried search on this..
i dont have a stand alone...you have 264's for both i and e?.......do yours have a purple marking on them...if you look into the head from the oil cap...
also..where on the cam is going to say it..when i pull the valve cover off will it say it in a spot where i can see if if i crank the car a bit
The code should be etched on the top end of each camshaft. JUN Japan website has more info.
http://www.junauto.co.jp/products/cy...t-4g63.html?en
It sounds like you bought the car used?
You should ask the person you bought it from; unless you bought it from a dealer.
They probably won't know anything.
BTW, a cammed Evo will sound very very different from a non-cammed Evo.
Also make sure you put your valve cover back properly.
Here's a good link:
http://evomoto.com/tech_info.php?tPa...621cbc01aa13f7
Here's a good link:
MR EVO 2410
May 23, 2007 09:10 PM
bovbilly
Nov 6, 2003 02:30 PM
