Who's 50 Trim Should I go with?
The BR unit would probably work the best being that it leaves room to afford injectors and a FMIC where as the AMS kit is $1,300 more. I also like the cast manifold, I bet it spools it faster being thermal coated and iron so it'll hold the heat better and shorter runners. Not to mention it is LOW key, it even house the OEM heat sheild.
I did my research ,the BR kit does not include the tubular manifold thats $800.00 more, it does not include the intake pipe or filter thats more, so when you added it all up the AMS is cheaper. BR quote $5850.00 shipped and AMS $4900. 00 shipped. With the BR kit you will need to buy their Race FMIC with AMS you can use stock or anything that bolts up to stock IC pipes...
Get his 50Trim, and get his DELUXE FMIC and intake and filter and you are STILL under 4 Grand
Where as the AMS and Shearer are 4 grand without the FMIC.
