turboxs tbe install questions
Old Feb 16, 2007 | 06:58 PM
jeffbum's Avatar
so ealier today i made a generous attempt at installing this exhaust, with the test pipe. the shop on my base wouldnt allow me to install the test pipe so i had to put the cat back on. so my question is, is there suposed to be a gasket between the dp and o2 housing? this may seem like a dumb question but i asked the distributor because the tbe only came with 2 bolts and 2 gaskets. which they explained to me that they were for the rear section. and now my dp leaks like thats its job?? not too happy
Old Feb 16, 2007 | 07:00 PM
2Devious's Avatar
Reuse the stock donut gasket between the DP and o2 housing.
Old Feb 16, 2007 | 07:08 PM
jeffbum's Avatar
yo know thinkin about it i didnt see one in the dp, or on the o2 housing...but im gonna go look one more time thanks
Old Feb 16, 2007 | 10:12 PM
evo150's Avatar
the stock spring bolts need to be torqued to 37ft-lbs. probably the same for the turbo xs
Old Feb 17, 2007 | 06:02 PM
jeffbum's Avatar
so i took off the turbosx dp and look to see if the stock doughnut gasket was there and it was, but there is a huge space where the stock gasket cannot possibly seal. after some research i found that there is supossed to be a hardware kit that comes with a large doughnut gasket and new spring bolts. right now i have the stock dp on until i can get turboxs to send me this hardware kit. but at least i got the race pipe on, and im suprised because it has yet to throw a cel light?
Old Feb 17, 2007 | 08:49 PM
stbrn19's Avatar
nvm, just re-read the post sry for the mispost
