Fuel pump whine?
Old Mar 13, 2007 | 04:28 PM
Blk04evo's Avatar
Question Fuel pump whine?
Just got my 04 evo. BONE stock as far as I can tell. There is a really really loud whine from the trunk, and it gets louder when I get on the throttle. Is something wrong or is this normal? Its VERY loud and noticable.
Old Mar 13, 2007 | 04:43 PM
jbrown's Avatar
Sounds like the prev owner upgraded to a Walbro GSS342
Old Mar 13, 2007 | 04:46 PM
recompile's Avatar
Um
My Walbro isn't that loud. I can only hear it when I'm at low idle (900rpm). But then again, I have turbo back exhaust so I'm sure if I had stock exhaust I could hear it all the time.
But anyways, I hope it's not your transfer case or rear diff... cause that would really really suck
Easy way to tell... pull the back seat out and put your ear up to the driver's side fuel tank access panel... if that's where the noise is, then yes, it's fuel pump.
Old Mar 13, 2007 | 06:14 PM
fusionchicken's Avatar
Originally Posted by ShamelessCookie
Um
+1
i drove around without the backseat after i installed my walbro and it was loud as hell...put the seat back on can't hear anything now.
Old Mar 13, 2007 | 06:18 PM
lilevo1's Avatar
yup thats what my fuel pump sounds like..
u can check it really easily though.. just pull the seat off, unbolt the pump cover.. the pump assembly is attached to it..
Old Mar 13, 2007 | 07:15 PM
Tribal's Avatar
fuel pump for sure, they all do it...some louder than others
Old Mar 13, 2007 | 07:28 PM
ries's Avatar
if you have an RS its even louder
sounds like its next to your ear when driving
Old Mar 13, 2007 | 07:34 PM
Blk04evo's Avatar
I expected a walbro to be loud, but I can't see this car having one. Can I check if its a walbro if I pull the rear seat off?
Is it safe to drive the car this way?
Old Mar 13, 2007 | 07:47 PM
DG Motors's Avatar
you would have to take the rear seat off, unbolt the fuel pump cover, disconnect the lines, pull up the fuel pump sending unit and look on the fuel pump itself to see if its a walbro (342) >>> will be stamped on the pump itself.
Old Mar 13, 2007 | 07:56 PM
Evol.ved's Avatar
The Whinebro can be pretty loud.
It can be a pain to get the pump out sometimes so you might as well order another walbro while you are taking it out to check.
The pump will be quieter the more gas that is in the tank.
Old Mar 13, 2007 | 08:04 PM
riceball777's Avatar
yeah the walbro whine can be loud
mine is relatively quite and you can only hear it if you really listen to it.
bit once after i drove my car really hard and after i let the car idel the walbro while was super super loud but it went after after the car cooled.
repairmanevo8
Feb 9, 2016 12:36 PM
Blumenthal300s
May 10, 2014 09:48 PM
TurboIX
25
Nov 1, 2010 07:52 PM
evo8forme
Oct 14, 2009 07:00 AM
philevo
Oct 17, 2007 07:09 AM
