Measurements of removed internals
Old Mar 15, 2007 | 06:38 AM
Stew's Avatar
I'm wondering if anyone can tell me what the measurements should be on a few different OK condition removed internals, specifically rod bolts and rod bearings.
2005 Evo VIII, internals removed at 15k miles.
They should be something like:
rod bearings (thickness at center): .0595 in
rod bolts: 2.3675 in
Anyone have OEM specs as well, and tolerances? Anything else to check for to show the engine was operating properly (i.e. no detonation and no stretched rod bolts from over-revving) other than spark plugs and pistons?
Basically I'm examining my motor to show the catastrophic failure was not user error. Thanks guys.
Old Mar 18, 2007 | 10:23 AM
Stew's Avatar
nobody? Any idea where i can get this information from?
Old Mar 18, 2007 | 10:35 AM
thebluesky's Avatar
Off the top of my head, the thickness of the bearings varies depending on the diameter of the journal as well the diameter of the rod opening. The service manual has all the information you're looking for.
Old Mar 18, 2007 | 07:51 PM
Stew's Avatar
Good idea.
I did find some info in the 03 manual that I have, which says when inspecting rod bolts, if the shank (i.e. length of everything minus the head) is longer than 2.71 inches, replace the bolt. The length of all of my bolts INCLUDING the head are under 2.4 inches, so it appears they are ok. Mitsubishi sure allows for a good deal of stretching though, almost .4 inches. Although, that doesnt seem right.
Old Mar 20, 2007 | 03:39 PM
Stew's Avatar
Originally Posted by Stew
is longer than 2.71 inches.
oops, I think that was for a different bolt.. It doesnt seem the service manual has the specifications of rod bolts or rod bearings..
Old Mar 20, 2007 | 04:25 PM
kekek's Avatar
Check here for 2005 info:
http://forums.ne-evos.net/phpbb2/viewtopic.php?t=248
Hope that helps....
Old Mar 20, 2007 | 07:15 PM
Stew's Avatar
Hope that helps....
Ahhh yes, I was looking for the 2005 specific manual. Thanks Kekek.
