Atp kit, will it work with a gt40r.
Old Mar 20, 2007 | 01:41 AM
blackonblackevo's Avatar
I have this Atp gt35r for my evo 9, would it be possible to change it up with a gt40r?
Old Mar 20, 2007 | 01:50 AM
vigilante's Avatar
I have an ATP GT35r too.. i am not too sure if you can upgrade to a GT40R.. What A/R is your GT35R.. Mine is a .82 which is the biggest.. i would be willing to swap the hotside with you if you have a .63 A/R...
Just an option...
thanks
Old Mar 23, 2007 | 08:32 PM
kouzman's Avatar
There is no way that the ATP hotside can turn efficiently the GT40R, even if it could be utilised, which cannot! different category of turbos mate!
And why do you want to get a GT40R if i might ask? You are asking about a MEGA POWER turbo, which demands at least 10 grand worth of other mods!
Even the GT35R is big! If you have the bog a/r keep it since you have a IX. With the Mivec and a good tuner you can lessen the lag and get satisfactory results....
Old Mar 23, 2007 | 08:39 PM
riceball777's Avatar
no there is no gt40 option
gt35r is biggest
Old Mar 25, 2007 | 06:39 AM
popadel's Avatar
I own a Evo 9 and live at 6000ft above sea level - 2000m.
I bought an ATP bolt on GR30R ATP kit and hit 415HP/405Lb on a dynapack wheel hub dyna. (pictures below are from the most stingy roling wheel dyna in town and not the dynapack) Had a few runs with a M6 and a Dodge Magnum SRT8. No contest. by the third gear im 8 car lenghts ahead.
Other supporting power mods are AMS front mount with pipes, and an Autronic ECU. Walbro fule pump and RC750cc injectros (these are at the limit now) HKS FPR running 3,5b fuel pressure, HKS silent high power exhaust with delete test pipe, and HKS EBC5.
For the money spent it is the best power mod to date. Graph attached at the fly but they are in KW and NM 367Kw/620Nm at 26psi (1,8b). (491hp/476Lb)
A
Attached Thumbnails Atp kit, will it work with a gt40r.-evo-30r1a.jpg   Atp kit, will it work with a gt40r.-evo-30r1b.jpg
Old Mar 27, 2007 | 12:29 PM
bolsen's Avatar
Like others said, 40r is a different turbo.
Old Mar 27, 2007 | 09:14 PM
Are you sure the gt40r is a different turbo jk.
maperformance
EvoX 'For Sale' External Engine / Power
40
Sep 11, 2015 12:56 PM
Mines Evo IX
Sep 2, 2007 11:04 PM
blackonblackevo
26
May 28, 2007 09:31 AM
vigilante
17
Nov 15, 2006 03:38 AM
vigilante
Sep 27, 2006 01:26 AM
