Which spark plug to replace with??
Old Mar 27, 2007 | 10:07 AM
V8EaterEvo's Avatar
Originally Posted by vmrevo9
so is the stock plug sparks recommended for a "stage 1 upgrade" with no meth or alky and running 23-24 psi on a stock turbo?
Really, if you upgrade to a colder plug then you get some sort of benefit. I really don't think it's that much of a benefit for the cost. But running the stock plugs on a stage 1 upgrade is just fine. You won't hurt anything.
Old Mar 27, 2007 | 11:40 AM
EvoLutionized8's Avatar
and how about a stage 3 with upgraded turbo??? I plan on running 24-26psi with a 20G9-5LT using 93 oct. thanks.. Mike
Old Mar 27, 2007 | 11:52 AM
BoostEEd's Avatar
ROFLMAO, its no wonder no thread around here ever has a definitive answer for the orriginal question asked. It gets so off base with everyone elses setups the original poster never gets a great answer.
Sounds like the stock copper NGK replacements are the way to go for the ORIGINAL question in this post
NGK BPR7ES
Which plugs should I put on my Duramax?
Old Mar 27, 2007 | 12:39 PM
4whlpl's Avatar
Or you can go with the BR7ES's. I'm not sure if there is a price difference between the protruding electrodes and non-protruding???
Old Mar 27, 2007 | 01:04 PM
Erik@MIL.SPEC's Avatar
FYI, when I switched to BPR7ES plugs from BR8ES plugs, my knock counts went up. A very smart guy on here Aby (screen name WOT) tunes Honda race engines for a living. He runs iridium 9 plugs on his DD Evo...because he gets them free from work. So, technically, you can run any plug you want. But I think colder plugs are better...especially on det prone gas like 91.
Everyone is going to have different opinions. Iknow some tuners who recommend the protuding plugs and some who don't. I've had good luck with the BR8ES plugs gapped to .024
Old Mar 27, 2007 | 01:16 PM
SEEnoEVO's Avatar
Thanks to those with the informative posts!!!
Old Mar 27, 2007 | 01:52 PM
evo150's Avatar
bpr7es gapped at .026
