Loud whining noise
Old Mar 27, 2007 | 02:38 PM
rallyevo8's Avatar
Loud whining noise
i have a loud whining noise coming from underneath my car near the rear axle/exhaust area does anyone know what it could be??
Old Mar 27, 2007 | 02:42 PM
evo637's Avatar
Blown Tranfer Case...Does it get louder at speed??
Old Mar 27, 2007 | 02:48 PM
bomjoon's Avatar
fuel pump
Old Mar 27, 2007 | 02:50 PM
evrblazin's Avatar
well that's where your rear diff is located... have you changed your fluids yet?
Old Mar 27, 2007 | 02:51 PM
Silver06evo9mr's Avatar
hahahahaha ur screwed look at my thread here:
https://www.evolutionm.net/forums/sh...d.php?t=254425
sorry to laught but i just made this same thread.. search!!
Old Mar 27, 2007 | 02:52 PM
no its not the rear of the car!! the t-case is done. it starts as a small groan in the tc vibrates down the hollow drive shaft then to the rear diff making it sound like its the rear
dumb mitsu replace my rear diff fluid, drive shaft and front diff fluids for free before they decided to void my warrenty and telling me they had no idea what was wrong... ITS THE T-CASE!!
Old Mar 27, 2007 | 02:54 PM
sorry one last thing.... call shep
Old Mar 27, 2007 | 03:03 PM
evrblazin's Avatar
^ I just read your other post... so did shep do a rebuild for you yet? if so how much?
Old Mar 27, 2007 | 03:08 PM
evolved83's Avatar
yea how much is it to do a rebuild of the transfer case
Old Mar 27, 2007 | 03:15 PM
ixbreaker's Avatar
hmmm...interesting. i had the same noise but we determined it was chatter caused by aftermarket diff fluid....switched back to oem and went away. came back 15k later. note: there wasn't much shavings on the drain bolt when the oem diff fluid was replaced, and then after only 30miles of the aftermarket fluid there were big chunks of metal. had to flush several time to get rid of the chatter. check ur drain bolt!
Old Mar 27, 2007 | 03:17 PM
evrblazin's Avatar
yea it's really hard to diagonse an issue like this over the internet anyway... take it to a dealer or better yet track down someone in your area who has done a lot of evo work. my 2 cents.
Old Mar 27, 2007 | 03:20 PM
Maverick750's Avatar
TRE just did my transfer case 100 shipping there and back its was 2200
Old Mar 27, 2007 | 03:40 PM
ixbreaker's Avatar
2300 not bad...
Old Mar 27, 2007 | 04:24 PM
sonicnofadz's Avatar
A transfer case currently cannot be rebuilt. The ring and pinion gearset in the transfercase is not being sold separately by Mitsu at this time, so the only thing that can be done is to buy a new transfer case, or send it to tre or shep, who will replace your ring and pinion with one they have on hand (taken out of another t-case). It is probably better to just buy a used transfer case and have the ring and pinion cryo'd.
Old Mar 27, 2007 | 04:38 PM
JeffMas1587's Avatar
+1 for calling shep. i ordered my tcase on march 19 and it was shipped to me by march 22. i was unable to get a rebuild because my ring and pinion went out so i got the stage 2 tc. i like it very much, its nice to lose that whining noise
