HKS DLI 2 install question
Old Mar 27, 2007 | 03:34 PM
dennyt4's Avatar
Hello. I bought a used DLI but don't have instructions...Can anyone tell me if it matters which set of harness plugs go to which coil?
Thanks for any help.
Old Mar 27, 2007 | 03:38 PM
Blue Evo 8's Avatar
Yes it matters, plug it up the right way and you should be good. The whole process should not take more than 15 minutes...
Old Mar 27, 2007 | 03:39 PM
dennyt4's Avatar
OK, I appreciate that, but could you tell me which side is which? Like I said - no directions came with it.
Old Mar 27, 2007 | 03:49 PM
Blue Evo 8's Avatar
The harness has two opposite ends... one end goes to the DLI, and the other two ends go inline between the coil pack harness and the other end I forgot which. I didnt use instructions to install it... its pretty much very straight forward
Old Mar 27, 2007 | 03:51 PM
dennyt4's Avatar
Yeah I got that far - took the plastic center section of the valve cover off and see that it's very simple to install, I just don't know if those two need plugged into a specific side of the coils.
Thanks for your help though.
Old Mar 27, 2007 | 05:12 PM
mikesevo8's Avatar
Lay the harness in the valve cover so the cable comes out of the drivers side.
The position of the connectors will now reveal which goes where; there will be a set by each coilpak.
Old Mar 27, 2007 | 05:14 PM
dennyt4's Avatar
THANK YOU! That's what I needed to know.
PHILLY EVO
Jan 27, 2015 08:38 PM
BocaShula
11
Jul 14, 2012 06:25 PM
Paul Nelson
15
Jun 19, 2007 02:44 PM
Batmann!
AEM EMS
12
Sep 11, 2006 07:32 AM
Yaroslav
11
May 6, 2006 11:38 AM
