fuel pump electrical harness
Old Mar 28, 2007 | 11:18 PM
trinydex's Avatar
so i got this pic right here
i wanna see the other side what shape are the pins??? can i use those baby blue female plug crimps to plug into these pins?
also... is the black and white thick wires the ground and power respectively?
Old Mar 29, 2007 | 04:50 PM
trinydex's Avatar
:[ no one knows?
Old Mar 29, 2007 | 05:59 PM
Sschmuve1's Avatar
What is it that you are doing? Is the thick white wire damaged near the top? Or is that just the pic?
Old Mar 29, 2007 | 08:45 PM
FullBlown's Avatar
The white wire is the power wire for the pump. The 2 small gauge black wires are the wires for the float valve.
Also you cannot plug anything into the otherside of the plug. The T-taps that were provided is big enough to tap those wires, but since you are running the baller supra pumps you have to run a relay since those pumps draw a crap load of amps. Give me a call if youve got questions bud
Old Mar 29, 2007 | 09:13 PM
trinydex's Avatar
not my pic so i don't know if there's damage on that wire but i did notice that.
Old Mar 29, 2007 | 09:25 PM
FullBlown's Avatar
That is a pic from my car. During the R&D of the billet pump assemblys, i had to test and identify wires that is why that looks damaged but its not.
Old Mar 29, 2007 | 09:32 PM
trinydex's Avatar
so even if only run one pump i still have to use the relay? if so i need one :\
Old Apr 14, 2007 | 04:34 PM
trinydex's Avatar
no one wanted to gimme the answer so i had to find it in a buschur pic
as you can see the fuel pump PLUG TAKES pins... it has sockets inside.
ahmedshaikhani
Aug 24, 2021 10:24 PM
3VOLUTIONIST
Mar 23, 2015 08:29 PM
Hell_Spawn
Jun 12, 2014 08:16 AM
Howulikemyevo
Dec 15, 2013 03:37 AM
jeandsm
Apr 20, 2011 05:25 PM
