Question about Tilton Clutch.
Old Mar 29, 2007 | 06:19 PM
cmbjive's Avatar
For those of you driving with the Tilton clutch combo I have a question. I just had this clutch installed and for most purposes it operates smoothly. It rattles some and when I engage the clutch there's a little whistling sound. I might be bothered by the latter, but not as much as this: every now and then when I'm driving at about 75 to 80 mph at around 4000 rpms, there's a strong vibration that kicks in. When I let off the gas for a few seconds, it goes away. I want to know is this normal with this kind of transmission, will it go away after a while, or should I have my installer take a look at it again? Any thoughts is appreciated.
Old Mar 29, 2007 | 06:21 PM
Paul Nelson's Avatar
Which Tilton Clutch?
Old Mar 29, 2007 | 06:30 PM
joeymia's Avatar
tilton rattles etc... but its just noise and should not be felt as a vibration. If you are feeling a vibration then something must be setup wrong.
Old Mar 29, 2007 | 06:35 PM
PVD04's Avatar
Is your check engine light on? That sounds similar to the issues I had with my car when the PO300 would show up. The car would start running properly as soon as I let off the gas for a second.
-Paul
Old Mar 29, 2007 | 06:36 PM
sleet's Avatar
When i'm on the highway with my Tilton if I let off the gas you can hear everything chattering and I can feel the vibrations.
Old Mar 29, 2007 | 06:37 PM
Hmm i haven't felt that on mine yet but all my driven has been at the drag strip
Old Mar 29, 2007 | 06:54 PM
KartaRailed's Avatar
Funny enough, the EXACT same thing happens to me, only when crusing between 75-85 on the highway, and right after lifting a little bit and then going back into it, it will lock up a little bit, and you have to lift again to get it to work right. The bad thing is, I have a Carbonetics twin disk, so its obviously not the clutch, I dont think its a bad thing though. I think after the slight lift the floating plate might start bouncing back and fourth really fast or something? I really have no clue lol.
Old Mar 29, 2007 | 08:12 PM
evo542's Avatar
my friend has the quarter master twin (very similar to tilton twin cermic) and it does the same exact thing you guys are describing. At around 80mph the car starts vibrating and the engine starts bogging, than after he presses the pedal and revs it up a bit it goes away . I told him the super light flywheel might be the blame for this, it is too light and the engine doesn't cruise as good when it had the heavy (oem) flywheel in.
Old Mar 29, 2007 | 08:17 PM
sleet's Avatar
^ Yeah, there are certain MPH's that the car just runs better/smoother at for some reason.
Old Mar 29, 2007 | 08:24 PM
I think that might explain it.
Old Mar 29, 2007 | 09:09 PM
Lucas English's Avatar
Most clutchs without sprung hubs will make the drive train chaug (rattle) on decel.
Old Mar 30, 2007 | 09:46 AM
jbrown's Avatar
+1 for PO300
Old Mar 30, 2007 | 01:33 PM
03EVO583's Avatar
I agree. It is most likely related to the solid hub discs. Sprung hubs are used to absorb harmonics/vibrations.
Old Mar 30, 2007 | 04:41 PM
socalmr's Avatar
i have a tilotn and it does basically the same thing- it is normal!!!
Old Apr 1, 2007 | 10:29 PM
cmbjive's Avatar
Welp, I guess that explains it. Sometimes it's annoying, but I've pushed it with the vibrations and the only thing is that the vibrations get a little more annoying, but as long as the tranny doesn't fall out while I'm doing 80mph I can live w/ the vibrations.
It's funny how different cars respond to upgraded trannies. My Type R accepted the clutch and tranny with no rattles and vibrations.
