Power Loss???
Old Apr 2, 2007 | 07:18 PM
SS3502EVO's Avatar
Power Loss???
I recently installed the DCSPORTS Turbo-back pipe which includes the cat-delete. I already had a GREDDY EVO2 Cat-back, and K&N Drop in filter. SO now I have a 3in turbo back, and drop in. However after I installed the turbo back pipe and delete, I noticed Alot more low end power and less power in 4th and 5th. It seems like its spooling slower top end. whats the prob? Low end its much faster. Do I need a Tune or flash. Will that fix the prob?
Also If I do go w/ a flash would the dealer be able to tell, if I needed warranty work?
Old Apr 2, 2007 | 07:21 PM
Warrtalon's Avatar
Can't help you on your butt dyno other than to say you should be using a dyno or drag strip to see gains (or losses), not your butt dyno.
The least likely thing for a dealer to find is a flash. They will 100% find your removed cat, which is not allowed. A flash is way more important than the exhaust, so get that done.
Old Apr 2, 2007 | 07:26 PM
SS3502EVO's Avatar
yeah If I ever need warranty work Im just going to throw my stock down-pipe and cat-delete back in.
I could just be getting used to the car and the gains could have been greater low end making it seem slower top in? But I def think it spools slower in 4th and 5th now, thats just me.
Old Apr 2, 2007 | 07:27 PM
SS3502EVO's Avatar
http://www.hopupracing.com/dcsptudopimi.html
http://www.hopupracing.com/grevexmilaev.html
this is what I have plus the drop in
Old Apr 2, 2007 | 07:45 PM
prj.evo's Avatar
get a flash
Old Apr 2, 2007 | 07:46 PM
Warrtalon's Avatar
Well, it takes 30 seconds to flash yourself back to stock if you use EcuFlash, which is much easier than replacing the exhaust parts. I can't imagine that you would spool more slowly in 4th and 5th, the gears with the highest load, after adding a test pipe and downpipe that reduces backpressure. That's the opposite of what should happen.
Old Apr 2, 2007 | 09:57 PM
SS3502EVO's Avatar
SO pretty much Flash it or tune and ill be fine.
To flash back and forth is pricey.
Old Apr 2, 2007 | 10:03 PM
mac_05evo's Avatar
No, it's not.. Buy yourself a $95 tactrix cable, get the stock rom off of your car and save it for later use and backup. Install the new flash using your cable and if the need ever arises, hook up the tactrix cable load your stock flash and done. Then after your done at the dealership or whatever you can put the "tuned" rom back in..
Old Apr 2, 2007 | 10:09 PM
SS3502EVO's Avatar
So you think my prob is I need a tune/ flash though
Old Apr 2, 2007 | 10:16 PM
mac_05evo's Avatar
As already said by Warrtalon, a tune is definitely going to net you the most gains.. Go for it
Old Apr 2, 2007 | 10:27 PM
SS3502EVO's Avatar
you can turn up the boost w/ a flash cant you?
Old Apr 2, 2007 | 10:35 PM
Warrtalon's Avatar
Not directly - just get an MBC. An MBC + flash costs less than your exhaust and makes more power.
Old Apr 2, 2007 | 10:40 PM
sparky's Avatar
This is a dumb question....but, do you have a boost gauge?
Old Apr 2, 2007 | 10:44 PM
Warrtalon's Avatar
Au contraire! It's a great question that could be potentially result in a dumb answer.
Old Apr 2, 2007 | 10:48 PM
Cali2MDevo8's Avatar
Registered User
Never liked the DC sport 2 in 1 downpipe just for the reason of having to put the stock cat back on for emissions. PA does emissions every year, right? Putting the cat back on is easier than putting downpipe and cat back on.
6466Animal
May 8, 2016 05:07 PM
Jdunn502
Mar 26, 2009 10:08 PM
sabastian458
24
Feb 15, 2005 09:17 PM
Wicked
11
Nov 24, 2004 11:29 AM
mojo
67
Nov 19, 2004 10:00 PM
