Can a o3 Evo transfercase be rebuilt?
Old Apr 3, 2007 | 12:58 PM
OtownEvo's Avatar
Can a o3 Evo transfercase be rebuilt? After it starts to WHINE.......Are o3 transfercase rebuildable?
Talked with couple vendors they say NO only BUY NEW one...Want to make sure this is accurate.....SUBTANTIAL DIFFERENCE from NEW to UPGRADED in cost????????
Old Apr 3, 2007 | 01:04 PM
94AWDcoupe's Avatar
No. no one makes a replacement ring and pinion. PM me if you are interested in a low mile used one with no whine.
Old Apr 3, 2007 | 03:41 PM
Evoloosin's Avatar
i was told that transfer cases could be rebuilt but i could be wrong.
Old Apr 3, 2007 | 05:53 PM
joeMama's Avatar
no....Ring and Pinion are not available!!
Old Apr 3, 2007 | 06:31 PM
DynoFlash's Avatar
You need to look at the ring and pinion and see if the teeth exhibit an usual wear Pattern
most of the transfer cases which make noise do so as the ring and pinion have a mis - matched engagement which results in un even wear and makes the noise worse and worse
if the ring and pinion are no abnormally worn - the case can be re-shimmed and corrected
From what I can gather a lot of bad transfer cases also result from using the wrong type of oil
ONLY Mitsu DIA QUEEN oil should be used
