HOW can i hold more boost????
im driving 2005 mr
mods:
-turbo back no cats
-filter
-hks recurculating bov
-fuel pump walbro 255ph
-mbc
street tuned
i have the mr gauges
it shows a high spike to 1.5bar sometimes over the gauge and drops down to 1.1-1.3
y does it go so low its so much its like from 21-14psi?
what do i have to do so i hold almost close to full boost lets say 21-20?
thanks guys
mods:
-turbo back no cats
-filter
-mbc
street tuned
thanks guys
How is your MBC connected to your WG and are you logging boost?
normal taper is 1-2 psi up top. yours is probably a loose IC hose or if youre losing too much pressure, i've heard that you should check the MBC install.
i've never experienced this much loss
you might look at the BOV and make sure theres a tight connection there as well.
mbc its connected to the turbo and wastegate acctualator
i cappped out the vga those 2 nipples and intake nipple and bov is normally conectedd vacume to bov
so yeah wastegate accutalator and turbo
so ur saying mine tappers too low?
tapering from 21-14 psi however, is not normal
i drove on race gas it was holding 1.5bar but than my pipes were coming off and i got t-bolts didnt brake so that was fine
but i had a bad mbc install so the vacume kept coming off
but it was holding lts of boost
does that help?
does that help?
