Got a busted Cam position sensor--ok to drive?
Old Apr 7, 2007 | 10:30 PM
belizelittle39439's Avatar
So I got an SES light the other day, and after checking it I was sporting a po365 on the obd II: "Cam position sensor bank 1 circuit malfunction"
Checked the engine bay--found a cracked sensor housing on the intake cam side. The local dealer is charging around $101.xx for it, and I haven't been able to get pricing from mitsubishiparts.net/com yet.
I might possibly be able to get it from another board member used.
But until that time comes--I was just thinking--is it okay to drive the car as-is? I would think the ECU would need to know this kind of information to make proper adjustments. I haven't noticed anything in my daily driving, and I'm keeping things toned down until I can get it replaced.
Does anyone actually know in detail what kind of information that sensor relays to the ECU? I know it's cam position--but if the ECU doesn't get a proper reading, what happens then?
Old Apr 7, 2007 | 10:32 PM
Sap12687's Avatar
I don't think the car will even start
Old Apr 7, 2007 | 10:36 PM
That's odd--because I've been driving it around for 3 days since I've gotten the error. The sensor is definitely busted though. Cracked almost all the way through. (Probably my fault when I changed out the thermostat housing for the one from 42nd designs with the adaptor for the water temp sensor--though I don't remember even touching that area of the wiring harness except to zip tie the wiring for the h20 sensor. )
Nonetheless, the car's running with no noticeable ill effects outside the SES. Just have to clear that error code every time I start the car. I actually get the same code twice. Once solid and one pending. Either way--the things busted and needs to be replaced.
Why would you think the car wouldn't start?
Old Apr 7, 2007 | 11:04 PM
Sap12687's Avatar
I might be thinking of another sensor but i do know that when i broke my cam ANGLE sensor that my car wouldn't start. Now that I think of it i'm pretty sure we're talking about two separate things.
I would get it sorted out before you do anymore driving.
Old Apr 8, 2007 | 09:08 AM
Perhaps. Well most likely since I'm driving. But here is the one that I busted and am now frantically searching for:
Old Apr 8, 2007 | 09:18 AM
Silk's Avatar
I busted mine when i was installing my upper intercooler pipes Anyway luckily my local dealer had one in stock and I think I got it for around $85. Just bolts right in. Is weird when busted it though, when i first started it up I could drive around fine, but then after coming back home it wouldnt start back up. Anyway, I wouldnt drive around with it busted as you might end up stranded
Old Apr 8, 2007 | 10:27 AM
KcEvil8's Avatar
A bad cam sensor won't cause the car not to start, but a bad crank sensor will cause the car not to start.
Old Apr 8, 2007 | 10:28 AM
ooooh, good point. It's still connected wiring wise, but the housing is all flimsy. It broke on the receiver end of the plug--at the bottom.
Old Apr 9, 2007 | 03:50 PM
Holy smokes...that was a 120 dollar mistake! Be careful when working that area folks...it's an expensive little spot.
lp_ceo
Sep 2, 2010 05:09 PM
bwagner31
Jul 23, 2010 07:40 AM
Noize
10
May 25, 2010 04:23 AM
broddey
Feb 18, 2008 02:06 PM
propellerhead
Aug 2, 2005 07:02 AM
