AEM ugeo questions
Old Apr 11, 2007 | 07:39 AM
deadbeatrec's Avatar
AEM ugeo questions
ok so AEM offers 2 types
1. Gauge-Type Wideband UEGO Controller
2. Wideband UEGO Display Gauge
i think the difference other than price is that the second one listed doesnt come with the o2 sensor. but if thats the case, then how is it hooked up?
also i was told that in order to instal one of these a/f gages that all u have to do is, weld the bung into the exhaust and instal the o2 sensor into the bung, then supply power and u are good to go. is this correct? also where on the exhaust does this bung have to be welded? pre-cat, post-cat, test pipe, where?
Old Apr 11, 2007 | 08:25 AM
anyone?
Old Apr 11, 2007 | 09:19 AM
Pr3z's Avatar
Mount before Cat if you have one. If not then anywhere in the exhaust stream will work.
The second one is assuming you already have a wideband O2 sensor from some other kit like an LM-1.
Old Apr 11, 2007 | 09:34 AM
ok so mount pre-test pipe in case i decide to put my HFC back on, and get the first one. ok now what about install?
Old Apr 11, 2007 | 11:21 AM
Pr3z's Avatar
Should be pretty straight forward. I'm sure it comes with instructions. The hardest part will be routing the wiring to the sensor. You'll have to have someone weld a bung for the O2 into your DP then.
