dip stick...low oil(HELP)
i just had an oil change 500 miles ago(mitsu dealership)... i was cleaning the egine bay today and pulled my dip stick...and it was low. it was lower than the lower grove. We installed my turbo back last week and we did see any oil or sign of an oil leak....i doule check it today if theres any leak...but there's none! what should i do? 03 evo gsr (got 35000 miles)
You didn't get ALL the oil in from the dealer. they didn't check probably. cost me a spun rod bearing.
They did an "oil change" and put 2 or 3 quarts in mine. The evo next to me on the lift got OVER 2 quarts on his oil change. same thing happened to him.
OR, you were aggressively driving your car with the new TBE and had blow-by.
My guesses.
I check my oil every time I fill the tank.
They did an "oil change" and put 2 or 3 quarts in mine. The evo next to me on the lift got OVER 2 quarts on his oil change. same thing happened to him.OR, you were aggressively driving your car with the new TBE and had blow-by.
My guesses.
well over 30 oil changes since I owned my 04, back when it was new I decided to go ahead and get the free oil change they promiced. Overfilled it 1 quart!
I had to siphon a qt out the dipstick.
Check your car on level surface - makes about 1qt difference on even slight inclines.
Your not burning oil or else you will have clouds of smoke at idle
So what exactly would be the consequences of overfilling a little bit? Got my o2 housing installed a week ago and had to add about a quart of oil. Ended up overfilling it a little bit, should I be worried? Checked the dipstick and it was just a little over the top notch.
Add some oil and check it again after the weekend if it is low or looks like it used a lot of oil give me a call on Monday. I will be back from ATL then. Don't worry I'm sure it is nothing, all engines use some oil, and liked smokedmustang said it probably blow by from harder driving.
