GT35R Numbers that should be expected (HP)
I have been told two diff storys on what to expect from the GT35R.
I'm going to get a .82 hotside and i want to run 30 psi or so. What do you think i could expect from the upgrade i have a built motor. the only thing that is stock is the turbo and man and intake man. Just need feed back to make it better
It really depends on the kit you choose, your supporting mods and of course the tune. Plan on making anywhere from 400-450whp on pump gas, 500-550whp on methanol and that could be about it for most kits. I made 598whp on race gas and 30psi (but could've done it on pump+meth) with the ETS kit but have seen numbers as low as 508whp at 32psi with other kits.
Tom
Tom
i put down 418awhp on 22 psi 92 octane.no meth.i had stock block,stock intake mani,stock head.parts are in my sig.
also had a stock slipping clutch.oh and stock uicp at the time...it was a pretty conservative tune...i think now with uicp,new clutch and get rid of my greddy IC i can put down a lot more on same psi...
Tom
Tom
i havent seen any evos with over 550whp on the stock ecu but i might be wrong. also the descrepency in power that you were mentioning tom could be due to descrepency's in dyno's, altitude, temp, humitidy, tune, ect not just the turbo kit. btw stomper since you live in utah and i do too you should give me a ride when you get this kit installed pm me
Well i got it tuned the other day on a dynopak. It is running 28 PSI and i made 571 awhp. On 91 and alky stock ecu and maf with 1000cc injectors.
I will post the dyno sheet here i a bit.
