clutch went out today
Ok my clutch went out today and the dealership said that they do a stock clutch and install for 908
387 for parts stock clutch
dont have time to save the money its a dd
521 for labor
Is this a good or bad deal?
521 for labor
labor for clutch is usually high as it takes 4-5 hrs to do the install.
If you have any tuners around (that work on the EVO) ask them how much it will cost. Parts you can probably call around and see if some dealership sells 'em for cheaper than what your dealership is quoting you.
goodluck
goodluck
You can contact TKMotorsports.com as they are in NC, maybe they can help you out with an aftermarket clutch and install.
They are in Northern NC, not exactly sure where you are located in SC though.
how long did the stocker last?
if it lasted you a while and you liked it, stick with it save some money...
but if you launch every day.. the look into a better clutch and sign up for couple C.C. =-p
