Car will not start after cam install, need help.
So I decided to upgrade my HKS 264s to GSC S1. Everything basically went fine. Put the car together, try to start it and the car only cranks but doesn't start.
Here is few checks I have done:
1. I have taken everything part again just to check if everything is tighten and plugged in.
2. The cam gears marks line up with the vavle cover marks.
3. I also opened the cam sensor cover to check on the trigger position and the larger vein is at the bottom how the its pictured in the evomoto instructions.(Note I never took the off the whole cam angle sensor assembly when installing the cams.)
4. Also changed the sparks plugs.
The interesting thing the seems to crank just fine, its doesn't start, it almost seems its just about to start.
Any ideas to check for tomorrow, please go for it.
ISSUE SOLVED
They are interchangable, same part numbers just different length wires for the other cylinders. It sounds like the issue I had with my BC 280's. All I did was crank it every 20 mins for a while to pump up the lash adjusters. After doing so the car started. (I also had to degree the cams to get it to start better, but that I think was due to the aggressive ramp of the 280's)
