Stewart Warner boost gauge?
Old Apr 23, 2007 | 08:48 PM
vwjeff's Avatar
I installed some SW gauges a few weeks ago. And I took out my Autometer 30/30, and put in a 30/40 SW.
https://www.evolutionm.net/forums/sh...d.php?t=262887
The first gauge I got was f'ed up, it reacted really slow and it was only showing 20psi max boost, were the autometer showed 23 . So I reinstalled my Autometer to check and make sure the line wasnt pinched somwhere, and it worked just fine. So I ordered a new 1 cause I didnt want to deal with sending it back ect...
So I get the new gauge and the needle is moving fast now when in vaccum and hitting the gas, but it only shows 20psi max boost
I have heard SW is one of the finist gauges out there but I am thinking differently Also the needle on both gauges I bought were sitting below 0.
WTF should I do, I mean is it possible for a the Autometer to be off that far.
I turned my boost up to 22/23 tonight on SW gauge and logged the car with Evoscan and I showed 0 knock, A/F checks out good on my UEGO in the high 10's on 94 pump.
I am chicken, here and need some advice!
Old Apr 23, 2007 | 08:51 PM
Ultimate CC's Avatar
its all relative, who says any gauge unless its a map sensor is 100% accurate...
Old Apr 24, 2007 | 06:38 AM
s2kguy's Avatar
First off, that autometer gauge isn't known for acuracey so I'd take its reading with a grain of salt. The best you can hope for is consistent inaccuracy, ie if its 2 pounds off its always 2 pounds off. Most mechanical guages aren't 100% accurate, just consistent.
Even the electronic ones seem to suffer from this come to think of it.
Old Apr 24, 2007 | 07:39 AM
yellowEVO21's Avatar
yeah the autometer could def be that much off....
Old Apr 24, 2007 | 08:11 AM
vwjeff's Avatar
Well I guess I'll just have to check the map senser readings and convert it.
Anyone else have any suggestions?
Old Apr 24, 2007 | 08:17 AM
Jrod@Buschur's Avatar
I had to exchange 6 SW boost gauges before I got one that was zero'd out.
Good product but POOR quality control!
Other than that I have had no issues at all. It is just as accurate as my Defi was (which was DEAD on the money). Autometer can tend to read off of the actual setting.
Old Apr 24, 2007 | 08:18 AM
s2kguy's Avatar
Buy an AEM Tru-boost.
Old Apr 24, 2007 | 10:20 AM
travman's Avatar
If your logs check out what are you worrying about?
Old Apr 24, 2007 | 10:27 AM
kimletrim's Avatar
Registered User
+1
Old Apr 24, 2007 | 10:38 AM
Ralph's Avatar
I'll be testing the accuracy of my SW gauge soon after I receive my JDM IX map sensor. My autometer was reading 2-3psi higher than the SW.. so one is definitely off .
Old Apr 24, 2007 | 01:39 PM
Chemwarrior's Avatar
I also had to exchange the first SW gauge I ordered due to it not being zeroed out. The second one I received was spot on and works great.
Old Apr 24, 2007 | 01:46 PM
Charlie_B's Avatar
If you have a mbc, how can you accurately check what your boost is? Fairly new here, but Im thinking that the logs would only show boost levels if you have the stock bcs hooked up, correct? Im looking at my logs, and apparently wasnt logging boost. I have an autometer, and would just like to see how off it is.
Mellon Racing
EvoX 'For Sale' Interior Styling
14
Jun 19, 2011 08:00 AM
vwjeff
May 3, 2007 08:44 PM
SRTRaceR04
Dec 25, 2006 09:44 PM
an0ther
Sep 16, 2005 08:19 AM
Kodiak
Mar 28, 2005 03:13 PM
