What should I expect at the dyno?
My '03 VIII made 303 hp/308 trq on a Mustang dyno running ACN91. Current mods are:
K&N drop-in
Hallman MBC @ 21psi
Forge by pass valve
Helix down pipe
Helix test pipe
Greddy EVO2 cat-back (modified)
HKS 264/264 cams
Nisei LICP
Walbro 255Lph fuel pump
Custom tune
I'm adding a gently used IX turbo, a ported stock exhaust manifold, and the correct eBay SS O2 housing.
What should I expect at the same dyno? Can I run more boost, or does the 91 limit me to 21 psi?
Thanks,
Jim
K&N drop-in
Hallman MBC @ 21psi
Forge by pass valve
Helix down pipe
Helix test pipe
HKS 264/264 cams
Nisei LICP
Custom tune
Thanks,
Jim
I would hope for at least 20whp. I was going to say get a 10.5 housing and get 10whp but it already comes with your 9 turbo so I think the turbo and the o2 housing should be worth more than 10 whp too.
I do hope you are simply pessimistic in general.
With used IX turbo, ported mani, O2 housing, and dyno tune, I'll have over a grand in this swap. I'll be disappointed if I only get 20 whp out of all of this.
IX turbo into an VIII: how much whp?
I thought a IX turbo swap to an VIII was supposed to be good for 25 whp, and a ported mani and SS O2 should add another 20 whp....
Am I off base here? Wishful thinking?
We'll see what it makes in a week or so.
K&N drop-in
Hallman MBC @ 21psi
Forge by pass valve
Helix down pipe
Helix test pipe
HKS 264/264 cams
Nisei LICP
Thanks,
Jim
K&N drop-in
Hallman MBC @ 21psi
Forge by pass valve
Helix down pipe
Helix test pipe
HKS 264/264 cams
Nisei LICP
Thanks,
Jim
Jim ,
Your Dyno numbers are fanstastic, My Evo 9 puts almost identical numbers minus the cams. I ran more boost on 91oct before I did the methanol but keep in mind I had a custom road tune.
Your numbers are in pair with my previous dyno numbers done with similar mods minus the methanol.
Definately nothing to worry about. By the way, you are in good hands with IAperformance and his great customer service and crew.
Carlos
Carlos
Dynojet
100oct
custom tune
he was on :
Mustang dyno
untuned
on 91oct
I am not trying to downside your numbers by any means,congrats by the way, but I want to make things fair, I have been on the same dyno that he dynoed his car and I can tell his numbers are very decent considering he doesn't even have a tune.
Carlos
