sean ivey=savage
Old May 9, 2007 | 08:42 PM
jezefink's Avatar
sean ivey=savage
so i had my car tuned today by sean. which he did a great job..put a few go fast parts on....the car was encountering a bunch of knock..he fixed it...fuel was all messed up...next thing i have a 1g bov...which was leaking...nothing a little hammering couldnt fix for a crush...this question i have is...this bov must be leaking alot...the car starts stuttering and not getting steady boost after 25psi....im recurculating so i cant go with a tial..what should i go with...
i was looking into the greddy type r...has anyone ran this..
Old May 9, 2007 | 08:44 PM
hamx0r's Avatar
i have a forge dv and love it... just a suggestion
Old May 9, 2007 | 08:45 PM
staatz's Avatar
Nice numbers, mods done and psi?
Old May 9, 2007 | 08:48 PM
gohdunlam's Avatar
+1
Old May 9, 2007 | 08:54 PM
jezefink's Avatar
the problem with the forge dv is im running a 1g flange...so i want to run a bov that is flanged not just hose...
Old May 9, 2007 | 10:22 PM
Danny23's Avatar
Keep the 1G,just do the dejon fix and you,ll hold the boost and still get that great 1G driveability.
Old May 9, 2007 | 10:27 PM
God Given's Avatar
Sean is the man! Best tuner and the best attitude around!
Old May 9, 2007 | 11:12 PM
Sean@Iveytune's Avatar
Plugs and BOV.
Should fix it.
Sean
Old Jun 4, 2007 | 05:41 PM
jezefink's Avatar
[QUOTE=jezefink;4314133]the problem with the forge dv is im running a 1g flange...so i want to run a bov that is flanged not just hose...
Old Jun 4, 2007 | 07:16 PM
MRevolutionRed's Avatar
i wouldnt even say one of the best tuners on the east coast..one of the best in the whole country. sean works magic. you pay good money for tuning why not know your getting the best. never have heard of him taking a shortcut and will always help you out no matter what it is.
Old Jun 4, 2007 | 07:21 PM
kjewer1's Avatar
1) You keyboard is broke, it only types periods three at a time.
2) I believe Forge makes a 1g version of their BOV, I see no reason why you couldn't bolt that on to your 1g flange, if you wanted to go that route.
Old Jun 4, 2007 | 07:26 PM
Hmoneybagz's Avatar
I've been running the greddy type s bov for 2 years now and I haven't had any problems with it. I was tuned by ivey also. Great tuner!!
Old Jun 4, 2007 | 07:28 PM
TTP Engineering's Avatar
Can't go wrong with Mr. Ivey.
Old Jun 4, 2007 | 07:32 PM
Warrtalon's Avatar
Whether the 1G bov is leaking or not, it is NOT the reason for what you described. Hell, the stock plastic BOV leaks after 13psi, but it doesn't cause the car to stutter and break up. That's not the indication of a weak BOV - it's an indication of an ignition problem or actual boost leak (e.g. loose IC pipe)
Old Jun 5, 2007 | 05:28 AM
TeStUdO's Avatar
That BOV pretty much sucks, I know from experience. It has awful fluttering problems.
I have the Buschur UICP that has the 1g BOV as well. During a boost leak test, even crushed, it leaked at 22 psi. My only option was to send the UICP back to Buschur and get it re-flanged or do the Denon fix. I did the latter and havent looked back.
As Sean said, get some new plugs and do the BOV and you will be fine.
