What boost are you running on IX's with pump?
Old May 14, 2007 | 11:21 AM
Barrett006@aol.'s Avatar
Just installed a boost controller, curious how much boost you guys with 9's are running on 91 pump. I'm holding 22lbs. I've seen people go up to 23 also... Comments?
Old May 14, 2007 | 11:23 AM
TeStUdO's Avatar
I wouldnt boost that high on 91.
Old May 14, 2007 | 11:27 AM
what would you reccomend 20, 21 highest, it sucks all we have is **** gas
Old May 14, 2007 | 11:29 AM
TeStUdO's Avatar
I would recommend not turning it up more than 20, especially without a tune.
Old May 14, 2007 | 11:36 AM
RoMeIX's Avatar
I am spiking to just over 21 lbs tapering down to just over 17 lbs, tuned though.
Old May 14, 2007 | 11:41 AM
mdsevo06's Avatar
21.5 with a tune.
Old May 14, 2007 | 11:47 AM
so 20 sounds like a good general number, im gonna turn down the boost, thanks for the help guys, any others opinions are appreciated.
Old May 14, 2007 | 11:52 AM
Ralph's Avatar
I boosted 23 lbs on 91 octane pump, it was quite fast and had 0 knock. Not sure why so many people think running lower boost than stock is really a good idea, even on 91 octane. Most of the California Shop tuners also tune for 23~ish psi.
Old May 14, 2007 | 12:02 PM
4WS Tuning's Avatar
most boost = less timing....
what do you want for the car to do? hp or fast spool?
Old May 14, 2007 | 12:44 PM
inco9nito99's Avatar
~24psi...93pump, bolt-ons, stock timing, zero knock.
Old May 14, 2007 | 01:22 PM
chrismnj's Avatar
25 psi on 93 pump with tune no problems
Old May 14, 2007 | 01:43 PM
High_PSI's Avatar
25 is pushing it, I will try 23PSI and then log from there. 25 is nuts. mike1023 runs 28psi on is 2004 Evo VIII on pump gas. He runs 11.23 @ 120MPH!!!!!
Old May 14, 2007 | 02:02 PM
Ralph's Avatar
With some pretty good weight reduction done.. .
Old May 14, 2007 | 02:06 PM
Tarmacisback69's Avatar
23 on 93
Old May 14, 2007 | 02:12 PM
KOEvo's Avatar
For Evo VIII's a good rule of thumb is to just match the last number:
91 = 21 psi
92(nw) = 22 psi
93 = 23 psi
94 = 24 psi
For Evo IX's, just add 1 psi for each of those; they have a more efficient head (for multiple reasons) and can handle a more aggressive tune without knocking.
You never want to be under 20.5, that is stock.
In all reality though, you should never really use your boost controller; you should leave it where ever your tuner sets it at.
dudical26
Jan 29, 2020 06:08 PM
GusandoX
Jan 16, 2017 09:34 AM
ArchieBabes
May 21, 2008 03:01 PM
andber
Sep 7, 2006 07:51 AM
4-BNGR
Jun 20, 2005 08:59 AM
