Can't boost past 12 lbs! help!
last night my boost started acting up. . and now I cant boost past 12lbs. Tried 3 different boost controllers and it still didnt work. . tried running with the lines disconnected (which it should run 30 psi plus)and still would barely boost dont know what the problem is! any ideas?? by the way I changed out the vaccum lines so
I have no leaks
I have no leaks
nope, even with the lines completly disconnected I cant get past 12lbs and with them disconnected it should go over 30. . Any chance its the spark plus? because I was hitting 22psi just fine 2 days ago and didnt touch anything. .
It could be the wastegate. It could be something else. Just make sure all other options have been explored first before buying one. It would suck to replace it and then find out its not the problem. Dont know what to tell you boss. Good Luck though.
I have an extra wastegate. I ran into trouble and someone on here was nice enough to give it to me. I ended up getting one from the dealer under warranty though, so now I have two. If you want to try it, you pay for shipping and I'll send it to you.
P0411
Jun 4, 2015 06:47 PM
jj922011
Apr 1, 2015 10:03 PM
I really dont want to have to buy a new wastegate and install it. Pita.
