Cant boost past 10 psi Need Help
Old May 26, 2007 | 09:16 PM
the1andonlyE's Avatar
Okay I got in my car drove down the street it was running fine pulled into the atm and when I pulled out my car would not boost over 10 psi and when it hits that it starts sputtering really bad. I have checked my upper intercooler pipe and the lines to the throttle body but still nothing and I have not changed anything. Does anyone have any idea what this may be? Could it possibly be my fuel pump or spark plugs? Any advice and help will be greatly appreciated.
Old May 26, 2007 | 09:23 PM
sparky's Avatar
Did you check lower IC hose connections?
Old May 26, 2007 | 09:44 PM
No I will do that first thing in the morning.
Old May 26, 2007 | 09:49 PM
sharkm87's Avatar
check boost gauge lines......happned to me once and that was the issue
Old May 26, 2007 | 09:53 PM
Checked them already and they are fine
Old May 26, 2007 | 10:52 PM
evo150's Avatar
check your boost contol lines(manual boost controller or stock solenoid). a line has come loose or a cut in the line. you are only running wastegate pressure.
Old May 26, 2007 | 11:02 PM
Luis@TTP's Avatar
check all the plumbing and turbo to intercooler and intercooler to throttle body and check the boost controller lines if it isnt a intercooler pipe then i would recommend a boost leak test so you can find the vacum hose or the leak yopu might have also check the fuel pressure regulator vacum hose i have had one or two of those pop off.
Old May 27, 2007 | 05:19 AM
sparky's Avatar
Well, Duh! That's because of the insane boost levels you guys are running! LOL
Old May 27, 2007 | 06:07 AM
Luis@TTP's Avatar
sssssssshhhhhhhhhh i run 4psi plus 30 lol its all in good fun till something breaks and then we improve these things
Old May 27, 2007 | 02:47 PM
How can I do a boost leak test. What tools do I need and where do I need to start. Also thanks for all you guys help you are the best!
Old May 27, 2007 | 02:53 PM
ak47po's Avatar
Check this out.
http://www.vfaq.com/mods/ICtester.html
Old May 27, 2007 | 03:13 PM
subrwho's Avatar
could be your wastegate. mine just went out
Old May 28, 2007 | 07:55 AM
Thanks for the link and Ill try the test but if it is my wastegate how would I know for sure.
Old Jul 6, 2007 | 11:55 PM
subrwho's Avatar
what was wrong?
Ralliart909
Feb 24, 2015 12:44 AM
ghad
May 25, 2014 02:27 AM
Riddle
Mar 26, 2014 11:15 PM
EvoDan2004
42
May 27, 2007 04:48 AM
chinto
13
Sep 5, 2004 07:55 PM
