Need Manual Boost Controler Help!
Old Jun 8, 2007 | 01:10 PM
App420's Avatar
npe
Old Jun 8, 2007 | 01:14 PM
Warrtalon's Avatar
Yeah, that's wrong. The bottom nipple of the MBC should go to your pressure source. I prefer to use the turbo, but in this case, your pressure source is the BOV line. Swap the connections on your MBC...
Old Jun 8, 2007 | 01:19 PM
dudical26's Avatar
Also I suggest to use the nipple on the turbo outlet pipe as your pressure source instead of tapping into your BOV line.
Old Jun 8, 2007 | 01:27 PM
mdsevo06's Avatar
In the "How Too" there is a very good tread that gives everything you should need, for this install. It will suggest that you use the Turbo as a pressure source as well.
Old Jun 8, 2007 | 04:13 PM
App420's Avatar
i actually used that how to, i must have misread it
