Redline trans fluid
Old Jun 10, 2007 | 06:41 PM
cfdfireman1's Avatar
yep
Originally Posted by revvin9k
Amsoil synthetic fluids through out the entire vehicle, w/ an Amsoil filter.
My car would shudder and make noises around turns with the Redline fluids.
You need to add a LSD additive to get rid of that shudder.
Old Jun 10, 2007 | 07:07 PM
Evol.ved's Avatar
I live in a colder climate area so I use 2qt mt-90 and 1qt MTL in my five speed.
Works very well.
Old Jul 10, 2007 | 01:00 PM
edzilla's Avatar
I've used Redline MT-90 for my trans, 75w90 in the rear diff and shockproof lightweight in the tc before.
I then switched to just Redline MT-90 in the trans and Mitsu Diaqueen in the diff/tc.
The Redline stuff is great but just be sure to change it out right after you get done with a track event as the fluids seem to break down sooner than the OEM stuff. This was done all in an 06 MR.
If anyone is in need of Redline Fluids, I am one of the larger distributors of it, as well as OEM Diaqueen! Please PM if you guys are looking for any Redline fluids in particular (motor oil, gear oil, shockproof, etc...). Thanks!
Ed
Old Jul 10, 2007 | 01:06 PM
schred86's Avatar
on the first change in the tranny i did bg syncroshift II, next one im doing redline, i still only have 1700 miles on her-
Old Jul 10, 2007 | 01:08 PM
TeKiZeRo's Avatar
I just did my tranny oil change and used: 2 quarts MT90 and 1 quart MTL and the transmission shifts soooooo much smoother. All the notchiness is gone .
Old Jul 10, 2007 | 04:13 PM
sonicnofadz's Avatar
Originally Posted by cfdfireman1
Yes I use redline lightweight shockproof recomended by AMS, Shep recommends the redline MT-90. Both great products IMHO. Diaqueen in the center dif Redline heavy with 1.5 oz. GM LSD additive in the rear.
Diaqueen in the center diff? The center differential is located in the transmission.
Old Jul 13, 2007 | 08:23 PM
benniboi08's Avatar
Hey,
I live in jersey and the weather can fluctuate from winter to summer and I was reading about users on the forum mixing mt-90 with MTL (redline fluids) Do i need to do this? I would rather use 2.9 quarts of mt-90 and this is gonna be my first tranny change. I just wanted to know if i will run into grinding or problems if i use only mt-90. car is stock.
thanks
Old Aug 7, 2007 | 06:57 AM
NWRacingscene's Avatar
Originally Posted by Evo8yurAMG
anyone use royal purple for there tranny?
I used the royal purple, it felt worse then syncro shift 2.. I am going to MT90 this week, with diaqueen in the transfer/rear diff.
SmurfZilla
Aug 16, 2015 03:50 PM
goforwand
Dec 29, 2013 07:47 PM
