Thoughts on going straight methanol? Fuel requirements? Ignition?Engine build?
any champ car engine running ~2001 spun between 15,500 (Cosworth) & 17,400 (Toyota) I have seen sound analysis confirming these engine speeds, as Honda Spun ~16,800 & sound analysis validated the numbers that we see/saw within ecu data.
to stay on topic-
methanol is awesome. sprint car guys run it too! talking about crazy power to weight ratio's
to stay on topic-
is block rigidity really a problem on the 4G63???
Chris.
Just to add to this limited methanol knowledge base on evom:
1850cc@45psi FIC injectors maxed out on an FP Red at 1.8bar at 0.65 lambda. We tried to increase base pressure by 10psi to get some headroom, but then the Weldon 2025 fell flat on its face once it approached 80psi total pressure. Seems a mechanical fuel pump, more injectors and CDI needed beyond 600chp. Interestingly, turbo spool was late compared to C16, possibly due to lower EGT's. As expected, fuel has a high threshold for ignition timing and compression, but not for running lean.
Check out WWW.moranmotorsports.com my injectors are on the way. Primary 235lbs an hr, 2467cc and the go up to 600lbs per hr.
cassidyb
Oct 2, 2011 11:29 AM
EVOlunchbox
Jul 17, 2005 02:04 PM
