Can someone help diagnose this oil leak (photos)
#31
The conclusion is that oil is/was coming from one of the intake manifold bolts, according to the dye tests. It could be a bad gasket.
We just tightened down the bolt. I also put in 2 catch cans -one on each valve cover vent to keep the oil out of the intake.
Despite these efforts, I still see a little oil underneath. However it seems to be a big improvement from before.
#33
Same mani, same gasket. We just tightened down the bolt. The amount of oil leak is very small -undetectable on the dipstick. Not sure why it leaks, or why oil is still getting into the manifold. But if the leak gets worse, we'll probably pull out the manifold and replace the gasket.
#40
Very old thread, but a4rontran what did you find? I've had this slow oil"seeping" condition for a long time and I'm still thinking if I should just continue to ignore it. It's not enough to drip on the garage floor, which makes me think it only seeps while the car is running, thus not leaking when stored in the garage. Also, not noticeable on the dipstick between oil changes.
I did do the 1x1 arp stud install, about 3 or 4 years ago.
Thanks,
JCG
Thanks,
JCG
#41
Thanks,
JCG
Thanks,
JCG
Read page 2 & beyond to hear that most that did the 1x1 procedure noted a small oil leak
https://www.evolutionm.net/forums/ev...ease-vote.html
chaotichoax
32
Feb 11, 2020 09:00 PM
RSMike
135
Sep 12, 2017 06:40 PM
WTB[SouthEast]: WTB: Evo 8/9 Baffled Oil pan.
_des_
Feb 7, 2017 07:13 PM
David Buschur
83
May 27, 2016 07:39 AM
