can't boost over 14psi, WHAT?
Old Jul 13, 2007 | 09:28 AM
outlaws69's Avatar
can't boost over 16psi, WHAT?
So, about two weeks ago, I noticed my car have lost a bit of power. First I was worried but because it wasn't really a big lost, I thought it was just weather (Seattle has been it the 80s)... A few days later, Blam... car was driving like a POS. I couldn't boost over 16 PSI (I do about 25-28 normally) so I was like I broke something. At first I thought it was my piping got loose so I checked everything, upper lower front back nothing... ??? So, I thought my boost control is dirty. Cleaned it out and check connection put it back in... nope still doing the same thing. At this time I said to myself I might have broke my turbo but I went on and checked everything else because the turbo is just too expensive to brake... so I checked all the plugs and wire, the fuel system, even to my ARC air box out and cleaned that. still nothing. So I put everything back together and thought I might have blow some kind of gasket, like the exhaust or head something is leaking right? No love. everything looks good. and so for one week I was driving my car like that 14 psi, got picked on by cars that I normally won't ever consider playing with. So, the following weekend, I look deeper took everything back apart and I realized I have missed looking at the coupler on the upper pipe. It has a cut on the bottom of it from rubbing against a bracket and the engine heat has dried out most of that... I guess I am writing this so if you run into the same problem, you might want to check the couple... hope this help!
Watch someone is going to come out and say something like I would have checked it first thing... Whatever.
Old Jul 13, 2007 | 02:40 PM
EV0lved's Avatar
which coupler on the UICP? and is it the stock piping? im assuming where it attaches to the throttle body?
Old Jul 13, 2007 | 02:43 PM
bluebyu36's Avatar
should of checked that first
Old Jul 13, 2007 | 02:48 PM
0E3vobutt3r's Avatar
let me know too i just posted a very similar problem. I cant go over 15 lbs...
kreionic's Avatar
That great that you found your issue but why is this in the advanced engine/turbo section?
Old Jul 14, 2007 | 06:28 AM
EV0lved's Avatar
because some ppl on here who actually work on their evos might know wtf is going on, not saying you dont, but he would get a definitive answer to the problem
Old Jul 14, 2007 | 08:20 AM
Warrtalon's Avatar
You don't put stuff in Advanced so that Advanced people will answer. It only goes in Advanced if it's an Advanced topic. This is newbie stuff.
Old Aug 9, 2007 | 06:25 PM
Evo818's Avatar
i dont have any cut hoses but i only hit 14 when i hold 22 all time when i launch at the track o ron street any one able to help me on what is wrong with it
Old Aug 9, 2007 | 06:28 PM
evohang's Avatar
plugs or mbc either one and check your couplers
Old Aug 9, 2007 | 06:30 PM
Evo818's Avatar
it cant be MBC cause when i freeway driving or anything else it holds 22 strong and it only boost 14 when i at the track and i have no clue why
Old Aug 24, 2007 | 12:15 PM
Evo4u2envY's Avatar
Pressure test for leaks...
deathtracks
21
Oct 24, 2015 11:01 PM
wazmunstr
Jun 28, 2014 05:54 AM
David Buschur
114
Feb 4, 2013 09:02 AM
car_nut15
17
Jul 7, 2011 09:18 PM
neodestroyer
59
Apr 9, 2009 09:42 PM
