Fidanza cam gear problems
Old Jul 17, 2007 | 05:48 AM
MadCrix's Avatar
Hey guys
so the mechanic mounted up the fidanza cam gears to the cosworth cam shafts..
now when he put back on the cam gear cover the bolt fo rht cm gear rubbing on the housing...
what do u recommend i do to solve this?
new cam gear cover? let it rub until it cut away the little bit inside that rubbing?
advice pls....
thanks
Old Jul 17, 2007 | 05:49 AM
lexat20's Avatar
dremel
Old Jul 17, 2007 | 05:50 AM
MadCrix's Avatar
dremel enuff to stop it or to cut a hole in the cover?
Old Jul 17, 2007 | 06:06 AM
Luis@TTP's Avatar
cut two holes in the cover in the right spot and it will go away do not let it rub till it goes away. thats your timing belt your letting plastic shavings fall into. or you can leave the cover off all toghter
Old Jul 17, 2007 | 06:08 AM
MadCrix's Avatar
but what about stones? and oh crap getting in there?
i live in the caribbean and it is very dusty here
Old Jul 17, 2007 | 07:36 AM
MadCrix's Avatar
ok i just spoke to another evo owner here in Trinidad and he said as it is the evo VII the cam gear cover has ribs on the inside to make it stronger. What he ended up doing short of buying the clear cam gear cover ( both of us like the stock look) he placed a shim on the top two bolts and it cleared the cam gears just enuff to stop it from rubbing
Old Jul 17, 2007 | 07:59 AM
MadCrix's Avatar
the other solution is the use the evo VI cam gear cover
Old Jul 17, 2007 | 08:36 AM
lexat20's Avatar
just dremel enough to stop it from rubbing. You dont need to cut a hole in it. Then you can keep the stock look you want.
dillons13
Oct 10, 2016 10:52 AM
THmotorsports
89
Nov 16, 2015 03:28 PM
MacMan
28
Dec 14, 2014 05:22 AM
evo8fl
Mar 28, 2006 05:25 PM
titaniumkingpin
11
Nov 29, 2004 01:43 AM
