Boost needle under idle HELP
Old Jul 31, 2007 | 06:08 PM
jhanksevo's Avatar
Hey guys I was just wondering if the boost needle under idle without applying any throttle should shake violently? What signs do this indicate if any? I was also having a problem with the shaking going WOT but I heard this is normal because of the higher load is this true?
Old Jul 31, 2007 | 06:15 PM
gsrboi80's Avatar
Vacuum leak, boost leak, crapy mechanical gauge
Old Jul 31, 2007 | 06:28 PM
jhanksevo's Avatar
i have the defi bf
Old Dec 27, 2008 | 08:29 PM
Neuspeed06's Avatar
Mine does this also, but only at idle. It has a small rapid shake, but is smooth during boost. Ill be checking for a boost leak tommorow to see if that is the cause. Anybody figure out what causes the shaking yet?
Old Dec 27, 2008 | 08:32 PM
19DB794's Avatar
I have two boost gauges in my Evo and they both hold a steady reading when idle. Is there a loose connection for the vacuum source on the gauge?
Old Dec 27, 2008 | 08:34 PM
Kracka's Avatar
It means its a fast reacting gauge that is adjusting to the pulses in the intake manifold as the valves open and close. Be glad you have a high quality gauge
