put uicp on , now tranny is jerking
i put the buschur upper intercooler pipe on with 1g bov didnt recirculate into intake, now when i drive it the tranny clunks in every gear , wont shift right, i have a problem with the transfer case already but it was fine in all the gears i could shift right but it still whined , but now its all the gears, and it feels like the clutch aint engaging right when i put it in gear , can somebody help me out with this?
Exactly what he said. Don't vent your BOV, it's going to make your car do what you are describing. Put the stocker back and test it or better yet put your stock UICP back on, send the Buschur one back. Get your money's worth and spend it on a more worthwhile mod.
I would say your issues is the venting your dv to atmosphere.....not the transmission. Why you did that is beyond me, if you want the psshh sound then get a cone filter. No need to re-invent the wheel, a little research and you would have known it causes driveability issues.
The bushcur uicp is a good mod because it shortens the charges pipes up which does help. The uicp's that are worthless are the ones that follow the stock piping route. The shorter you can make your charge pipes the better you will be.
with the buschur licp i had to take off the turbo inlet pipe and it bolts right to the bottom of the turbo , and i had to move my boost controller to tube bov vacuum source is that the only way i could go?is that ok ?
